VE To A P-pump
Old 07-11-2007, 06:57 AM
2141pete's Avatar
Default VE To A P-pump
I have been thinking about buying a 1st gen to play around with. Is it hard to P-pump one? Will it make good power like a 2nd gen 12V will? Just an idea I had and I was wondering if anyone had done it here. Thanks in advance,
Pete
Old 07-11-2007, 09:37 AM
DBogo's Avatar
it will make good power and its not difficult to do, i guess it can be done for around 2500 bucks
Old 07-11-2007, 09:56 AM
2141pete's Avatar
would it be streetable? I know they say a P-pump conversion is supposed to be anstreetable on a 24V.
Old 07-11-2007, 10:01 AM
DBogo's Avatar
it would definatly be streetable, no reason why it wouldnt be
Old 07-11-2007, 10:10 AM
2141pete's Avatar
Sweet, what all do you have to change? Is it just the injectors, lines and the pump?
Old 07-11-2007, 10:13 AM
DBogo's Avatar
i beleive the pump, lines, timing case, and a few other things, i think the injectors can stay
Old 07-11-2007, 07:54 PM
Rebel Ram's Avatar
The 12 valve Cummins be it the VE pump or P7100 are for so much conversation Identical. Save for the pumps and harware that it bolts to.
But if I may, The whole charm of the Gen 1s IS the VE. Do get the truck, but give the VE a chance.
Old 07-11-2007, 10:21 PM
2001shrtbedcummins's Avatar
yea you need a new timing cover I believe. new injector lines, adaptors for injectors...and the actual p7100 itself...that will set you back a pretty penny. If you found a wrecked truck with one then it would be ideal as you have all the parts.
Old 07-12-2007, 12:20 AM
2141pete's Avatar
It was just an Idea. I have been reading and the VE doesnt sound too bad. I am trying to decide if I wanna keep mine and buy a 1st gen or try something else. Thanks for all the help guys.
Old 07-12-2007, 09:52 AM
you can get the be to 400 hp....but it will be a chore...I know you can put a bigger pump head on it to flow more fuel. But the ve is part of the character of a 1st gen.
Quick Reply: VE To A P-pump
