04 Duramax starting problem
I have the same problem at 85,000 miles. replaced the starter and it is worse. It's like the starter is spinning too soon and hitting the the flywheel. The old starter showed good engagement wear pattern on the teeth. I have not seen a post anywhere that has found a solution and some are two years old. Maybe they found the solution and stopped posting?
I put a new starter in it and it works much better. I had to remove the exhaust pipe to get the starter out. I expect I will put in multiple starters unit I get one that does not spin the starter too soon. Trial and error seems the only choice now. Seems nothing is wrong with the flywheel, it is all caused by the starter. I am selling the truck tomorrow, so I hope it works for him!
burndiesel
10
02-07-2023 01:15 AM
jeremy01995
09-14-2015 06:34 PM
dc2188
09-05-2015 10:41 AM
duramaxtuner
12-10-2014 01:24 PM
