turbo isnt working
Old 11-02-2009, 12:37 PM
royslsbry's Avatar
Default turbo isnt working
I have a 2000 f350 with a 7.3 and the turbo isn't working. i dont have a check engine light on i have checked the turbo it is still turning and looks alright. i dont have any exhaust leaks and the truck doesn't smoke. the truck runs fine other than the turbo doesnt kick in any suggestions?
Old 11-02-2009, 02:23 PM
Whit's Avatar
Site Mascot
if its still turning and ya have no smoke then its prolly fine
more detail please
Old 11-02-2009, 02:58 PM
royslsbry's Avatar
the truck doesnt have any power and you dont hear the turbo kick in
Old 11-03-2009, 09:49 PM
CSIPSD's Avatar
I moved your thread down here where it will get a bit more exposure...
Check all your boots, from the turbo to the intercooler, and from the intercooler to the Y pipe... Also check the boots under the Y pipe.
Also check to make sure the MAP sensor is hooked up on the Y pipe as well.
Old 11-07-2009, 07:39 PM
4x4_Welder's Avatar
Have you checked for codes?
Check for any restriction in the exhaust, plugged air filter, etc.
Old 11-08-2009, 09:38 PM
royslsbry's Avatar
no exhaust restriction and no codes
Old 11-09-2009, 01:47 PM
CSIPSD's Avatar
Did you see these questions... check EACH boot, feel it for tears or blisters...
Also, is there a loud hiss sound from the exhaust?
Old 12-01-2009, 12:53 PM
pepe's Avatar
sounds like exhaust back pressure sensor/valve.that same valve is what the 7.3 uses to help the engine warm up.you can also get an exhaust brake from ford that gives you manual operation of that valve.those valves can get gummed up,when they do it's like driving with the brakes on,plus it will hiss out the exhaust.
Old 12-03-2009, 09:57 AM
autofabricator's Avatar
you could aslo check to make sure the waste gate is not stuck open.
Old 12-03-2009, 07:44 PM
coldair's Avatar
no power could be from no fuel pressure. you need a boost gage or a scanner that can read live data to see what your boost is
Quick Reply: turbo isnt working
