6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
How to make turbo spool faster?
Old 11-09-2009, 05:11 PM
crewed powerstroke's Avatar
Default How to make turbo spool faster?
I had someone tell me there is some sort of electronic box that you plug inline with turbo ,that will make it spool quicker? Is this item out there , and does anyone have any info on it? Or was I misinformed and this person I talked to full of B.S.?
Thanks for the input.
Old 11-09-2009, 06:43 PM
HeavyAssault's Avatar
FICM tuning and a modded EGR up-pipe will do this for you.
crewed powerstroke (11-11-2009)
Old 11-09-2009, 09:05 PM
04redstroker's Avatar
There is such a thing. BD makes it, I bought it a few weeks back, but havent had time to install. Im gonna run it along with my tunes and see what happens.
Old 11-10-2009, 11:07 PM
I just read about this, and it doesn't make much sense. I've never really heard of one cutting fuel like that and losing power from too much boost, other than holding it too long. I run over 35psi almost every day and have never had this happen.
Old 11-10-2009, 11:28 PM
2500HeavyDuty's Avatar
they make stuff like that for duramaxes, to controll the vane position of the turbo and close them to increase the drive pressure and make the turbo spool faster. I think brayden fleece might make a standalone controller for the fords to where u can control the vaines on the 6.0
only negative effect i can think of is it hurting the performance is it causing too much drive pressure it chokes the engine.
bryadens controller can be used to bolt on even a 6.0 turbo onto any vehicle too.
Old 11-11-2009, 10:27 AM
If I do a full EGR delete , and get in touch with Innovate to see if they adjust for the FICM , you're thing I'll be in business? Thanks for the input.
Old 11-11-2009, 06:40 PM
Yep...best thing to do. Full delete is a bit overboard but if you got the cash and time then do it.
crewed powerstroke (11-25-2009)
avatardvr
18
08-08-2019 12:38 AM
Finn92
02-24-2015 10:41 PM
n2brk
02-21-2015 09:05 AM
wpg6.5
5.9L 12V Performance
9
01-07-2015 08:19 PM
GreenDieselF
10-20-2014 02:05 PM
Quick Reply: How to make turbo spool faster?
