Shaving The Timing Advance Piston
Old 01-06-2010, 12:40 AM
Alwaysworking's Avatar
got the testing done,
but the numbers they use are timing piston travel from
1.9-2.0 mm @1000 rpm pump speed
to 3.8 mm @1000 rpm pump speed
and went to 6.4mm @1500 pump speed
from what he said the engine speed is double the pump speed.
  #52
Old 01-06-2010, 01:33 PM
remps's Avatar
So how does the dynamic timing range compare to a stock pump? How much extra range does the spacer give?
  #53
Old 01-06-2010, 03:41 PM
oklahoma_6speed's Avatar
price on track bars.. and intake horn... so i can tell some people...
  #54
Old 01-06-2010, 04:47 PM
seandonato73's Avatar
  #55
Old 01-06-2010, 05:43 PM
RSWORDS's Avatar
and it still keps the stock base timing?
  #56
Old 01-06-2010, 07:16 PM
It doesn't change the static timing just the dynamic timing,
the top numbers i posted are stock settings and the bottom numbers i posted are what it was with the spacer.
2.6 max dynamic timing stock
to
6.4 max dynamic timing with the spacer kit.
Last edited by Alwaysworking; 01-06-2010 at 07:16 PM. Reason: Automerged Doublepost
The following 3 users liked this post by Alwaysworking:
Jet A Fuel (01-06-2010), MD 91 (01-06-2010), RSWORDS (01-06-2010)
  #57
Old 01-06-2010, 09:05 PM
lumpdog's Avatar
Very curious to see some real world seat of the pants results.
Smoke?
Power?
EGT?
Dyno run numbers?
Looks awesome though.
  #58
Old 01-06-2010, 09:12 PM
remps's Avatar
X2!
  #59
Old 01-06-2010, 09:26 PM
1STACK's Avatar
What is 1000rpm pump speed in engine Rpm/speed?
  #60
Old 01-06-2010, 09:36 PM
captain_stabbin's Avatar
this ones too high tech for me!!!
Quick Reply: Shaving The Timing Advance Piston
