Air filter choices
Old 12-15-2009, 08:17 AM
woodly1069's Avatar
Default Air filter choices
I want to add a new performance air filter to my old 12 valve but am a little confused about all the numbers. Can anyone help me understand why they want so much $$$ for some of these "cold air kits"? What about using my standard air box with a K&N? It's MUCH cheaper...Why would I spend so much extra cash?
Old 12-15-2009, 09:22 AM
PhilipR's Avatar
Well if you want to use the stock box i woul NOT put a K&N in there unless you want a new turbo shortly after. Amsoil makes probably the best drop in filter. The higher cost of most of those kits is because they come with piping, filter and a new box. Do a search for a BHAF and you'll get away with a lot cheaper "cold" air filter kit.
Old 12-15-2009, 09:27 AM
Lil Red Express's Avatar
Don't use a K&N drop in! I did on 2 trucks and it would not seal, kept gettin dirt on the turbo blades. I don't know about you but I can't afford to burn down a $5000 engine from a $75 filter not working right.
Old 12-15-2009, 09:30 AM
Whit's Avatar
Site Mascot
Fleetguard AH19037
NAPA 2790
WIX 42790
Baldwin PA2820
Hastings AF1012
Donaldson B105006
Donaldson ECB15006
Cummins 3912986
Cummins 3924541
Fleetguard AH19037
Baldwin PA-2806 (metal housing)
Baldwin PA2820
Old 12-15-2009, 09:32 AM
rkadcock's Avatar
N.M. Bombers Director
JMO don't use a BHAF, get a reusable AFE filter, it'll cost a litte more initially but once you clean it and re-use its paid for itself.
As for cold airs being so expensice, like duster said, it's mainly because it come with a new box, filter, tubes, and boots.
Old 12-15-2009, 09:35 AM
woodly1069's Avatar
OK, I guess I need to ask the question without sounding too dumb here...What the heck is a BHAF? What about S&B? I just don't know what they stand for? Where could I find a photo of each? Do they have a turbo tube or are they just filters for use in my stock air box?
Old 12-15-2009, 09:37 AM
Big Honkin Air Filter. Most come with a new box and turbo tube. I have used AFE for several years on 3 trucks with no problems.
Old 12-15-2009, 09:42 AM
woodly1069's Avatar
Does the BIG HONKIN AIR FILTER just sit in place of the old air box? What about engine heat? How long would this type of filter last? Is it washable? Oiling type? What about cost and where would I buy one? Would it fit my stock turbo intake tube?
Old 12-15-2009, 09:44 AM
rkadcock's Avatar
You can get just the AFE filter and stick it on the stock tube, same with the BHAF.
http://i197.photobucket.com/albums/a...95/BHAF003.jpg
Cold Air Intake System Stage 1 Dodge Trucks- 94-02 L6-5.9L (td) 54-10071 - aFe Power Diesel&model=2500&year=1997&diesel=true&brandID=52
Also you'll be removing the box, and you'll have to make a heat shield if the heat bothers you but theirs a guy on here that makes heat shields for the BHAFs
Old 12-15-2009, 09:55 AM
woodly1069's Avatar
Should I use the stock tube or is there room for improvement?
The AFE link provided shows three different filters. Two have a cone in the end which I assume is a good thing for more air flow but the most expensive one has no cone; why? Is there an advantage of one vs. another?
Quick Reply: Air filter choices
