turbo flutter
Old 12-25-2009, 12:56 PM
tcyr1316's Avatar
Default turbo flutter
Ok started noticing my turbo making a "fluttering" sound when spooling up in 4th and 5th gear. Doesnt do it in any other gear. Sound starts at about 15psi in 4th and 10-15psi in 5th. Any ideas what is causing this and a solution?? Thanks guys
Old 12-25-2009, 01:22 PM
wildbill's Avatar
Wastegate issue??
Old 12-28-2009, 07:27 PM
CSIPSD's Avatar
Surge... Quite common. ATS compressor housing WILL fix it, Wicked Wheel compressor wheel might fix it...
Originally Posted by RAM CR 24V
Wastegate issue??
You will NEVER hear a wastegate on a 7.3.
Old 01-02-2010, 11:06 AM
sandfley3208's Avatar
If your really broke a wicked wheel by its self will cure it
Old 01-03-2010, 03:25 PM
CSIPSD's Avatar
Can cure it... It works on about 80% of trucks...
Old 01-04-2010, 12:35 PM
dirty balz's Avatar
you say it works on 80% why is that? supporting mods cause it? if so how much power can you put through the wicked wheel before it becomes more of a problem than a fix?
Old 01-04-2010, 04:58 PM
CSIPSD's Avatar
Tuning, tire and gearing play a huge roll... as due elevation and driving style...
There is NO place where the WW becomes a problem that is not overall caused by the stock turbos limits...
ie, wicked wheel or no wicked wheel, the stock turbo is not happy above 30psi...
avatardvr
18
08-08-2019 12:38 AM
Hogridenfool
11-20-2017 04:37 PM
Finn92
02-24-2015 10:41 PM
n2brk
02-21-2015 09:05 AM
GreenDieselF
10-20-2014 02:05 PM
Quick Reply: turbo flutter
