Exhaust manifold
Old 12-29-2009, 02:32 PM
missile150's Avatar
Default Exhaust manifold
Does the 1993 6.5l td have gaskets between the exhaust manifold and the engine, or are they directly mated to the engine without them? The reason I ask is that a gentleman over at Heath Diesel said they don't, and one of the two manuals I have says it does. It refers to removal of the manifold and making sure the gasket is cleaned off well. Then the other manual I have gives no reference to the gasket. So I hope you can see why this is confusing to me. Thanks.
Old 12-29-2009, 09:12 PM
Woody35's Avatar
mine dont
Old 12-29-2009, 09:25 PM
missile150's Avatar
That's what I thought, too. Thanks, Woody. I think I have an exhaust leak, and was trying to start eliminating things. If it is from the manifold, what would be the best way to clean it after I get them off.
Old 12-30-2009, 02:22 AM
Woody35's Avatar
well if you had access to a sand blaster that would be the easiest for you but if you dont i would get a knotted cup brush that you put on a drill. i used that for cleaning my intake manifold and my tranny pan when they were off.
Old 12-30-2009, 09:35 AM
missile150's Avatar
Looks like the exhaust leak is between the turbo and the down pipe, either a busted/loose flange or a crack right on top of it. So I guess my new exhaust project just jumped up a few months, rather than dismantle it, fix it and put the old stuff back on. Now as for what type. I think I am going to go with the 4" aluminized from SS Diesel, including the 2.5" crossover pipe, new hardware and tip. Now I just have to convince my wife. I don't really plan on having this truck for more than 5 or 6 years, so the stainless steel option doesn't interest me, especially for the increase in price.
Old 12-30-2009, 11:57 AM
Woody35's Avatar
i would check the clamp first to see if its busted.
Old 01-01-2010, 06:47 PM
missile150's Avatar
I purchased a 4" exhaust from warp speed performance with a new crossover pipe and stainless steel tip. Should be here next week and I hope to have it on in a week or two.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
10-21-2015 03:30 PM
Jet A Fuel
08-03-2015 10:45 AM
Jake12valve
05-10-2015 11:57 PM
Old12er
02-20-2015 10:35 PM
cummins Pride
10-23-2014 01:10 PM
Quick Reply: Exhaust manifold
