glow plugs not workin?
Old 01-27-2010, 02:37 PM
FIRST GEN. JAKE's Avatar
Default glow plugs not workin?
my glows aint workin and the light aint comin on the dash. i can hear the relay click on and off.. i checked the fuse and its good. what can icheck to fix this?
Old 01-27-2010, 03:02 PM
ArizonaRedneck's Avatar
1st Gen Intake Manifold Heater check this out and see if it will help you out and its brought by our own rswords
Old 01-27-2010, 04:54 PM
tltruckparts's Avatar
are you using a chevy truck or a dodge truck like in your sig. if its a dodge you dont have glowplugs. but if your referring to a chevy let me and ill try and help. just a little confused as to what your asking about. a little more details and ill try and help you out
Old 01-27-2010, 08:13 PM
Woody35's Avatar
if its a 6.5 i would make sure the relay was getting adequetate power and think about replacing it
Old 01-27-2010, 08:51 PM
well sorry for the confusion but i posted this in the 6.5 thread for a reason.. i have a 94 chevy 6.5. wondering whats causin the light and glows to not come on.
Old 01-28-2010, 01:46 AM
are you sure the glow plugs arent working or are you assuming theyre not working because the light wont turn on.
if your not sure whether or not theyre working id do as woody said and check the relay. and just for the sake of stupid things happening and over diagnosing, have you checked the bulb itself on the glow plug indicator? theres a chance it couldve gone bad. if all your fuses relays and bulbs are good, it would start to think either a bad wire somewhere or a computer problem
Old 01-28-2010, 04:41 PM
well first off it wont start so unless i put the ether to her so i know my gp's aint heating. idk how the best way to get to the bulb for the light to check it. how can i test the relay? would turnin the key on and puttin a test light on the out goin wires work? i used jumped a wire across the two wires comin off the relay the other day and it had power cause it arched off. wat can i check. i dnt wana keep startin my truck on ether.
Old 01-28-2010, 10:38 PM
Woody35's Avatar
see if electricity is going to relay and if its coming out.
Old 04-16-2010, 05:51 AM
did you ever get it to work?....im having the same problem with my 94 6.5.
Old 04-16-2010, 02:56 PM
87diesel's Avatar
check power inlet to power outlet powe.then if thats good check power in let to each wire plug where the harness is pluged into the glow plug relay.. if any are bad then the relay is bad.. i skiped it all and just replaced the damn thing its only like 70 bucks.
Quick Reply: glow plugs not workin?
