7.3 lift pump pressure?
Old 02-18-2010, 12:56 PM
77scoutracer's Avatar
Default 7.3 lift pump pressure?
Does anyone know what the lift pump pressure should be on a 2000 7.3?
Old 02-18-2010, 02:53 PM
joebob3093's Avatar
Moderator
i have mine set about 68psi
Old 02-18-2010, 03:43 PM
thanks for the info, my pump is still stock so should it be making 68psi? Also I noticed you have your IPR shimmed, what does this do for performance? Sorry for the dumb questions
Old 02-18-2010, 04:02 PM
CSIPSD's Avatar
You do not have a lift pump... You have a fuel pump.
Factory pressures are anywhere from 40 to 70 or so. You can shim the Fuel Pressure Regulator to what ever you would like, but anything over 70 and you risk blowing the fuel bowl cap off or fuel leaks and your over working the pump.
He does not have his IPR shimmed, he used to have his FPR shimmed but now is running an aftermarket fuel pressure regulator.
Raising the fuel pressure does nothing for performance so long as your pump is maintaining 50psi or better.
landon025
09-08-2015 09:21 PM
Renteria1217
04-16-2015 11:38 PM
klein444
02-21-2015 10:33 AM
moneypitk5
02-12-2015 11:01 AM
veggyoilkid
11-10-2014 12:39 PM
Quick Reply: 7.3 lift pump pressure?
