leaking fuel filter
Old 03-12-2010, 10:06 PM
830cummins410's Avatar
Default leaking fuel filter
Ok Im finally getting the feel for my truck. got the tanks workin rite made a cold air kit for it and got a sh*t ton better mpg out if it made a manual adjuster to control boost straight piped it about an hour ago. gettin here where im pretty happy but my fuel filter keeps leaking every few days ill come outside in the mornin and there will be a little puddle of fuel under it and the filter or the cap will be a touch loose. anybody else had this problem? i was told if i go buy the motorcraft filter this will stop?
Old 03-12-2010, 10:39 PM
redneck817's Avatar
i dont know what to tell ya mine leaks a lil out of the fuel water seperator
Old 03-13-2010, 01:39 AM
Sycostang67's Avatar
I've had that happen once, oddly enough no fuel leaked out but it was letting plenty of air in. I just tightened it down a bit more and it hasn't happened since. You can get a wix filter that eliminates the bottom cap. It has the drain valve built into it and it has a port to put in your water sensor.
Old 03-13-2010, 12:06 PM
redneck817's Avatar
i plan on puttin a wix filter in but got to wait a lil will to save up to get it and a couple a 80 gallons of fuel got alot of fuel filters to change
Old 03-13-2010, 09:56 PM
cool thanks ill give the wix filter a shot even though it does back off from the bottom is where it leaks a little
Dbleo351
11-20-2016 09:34 AM
jeffersonl
11-15-2015 07:35 PM
ctjkelley
06-03-2015 06:01 AM
moneypitk5
02-12-2015 11:01 AM
jeffersonl
10-25-2014 06:46 AM
Quick Reply: leaking fuel filter
