Blowby Test*
Old 09-05-2007, 02:53 PM
Whit's Avatar
Site Mascot
Default Blowby Test*
By Bill Flemming
A better way to check engine condition is by a blowby test. This is what Cummins uses and is very simple.
You need a blowby tool. a blowby orifice tool is simply a tee with one .221" (15/64-in) outlet. Connect one end of the tee to the end of the blowby tube. Put a manometer on last tee outlet. That is your blowby tool. They sell them at the Cummins, but I have made my own plenty of times. A simple manometer can be made by looping into a U 6' of clear tubing with water in it half way. Measure how high the water level rises with a tape measure, multiply it by 2, convert it to LPMs
Rough conversion is 1"= 27 lpm, add 3 lpm for each one inch (1/2'' of rise in the tube) of water
New engines numbers are;
63 liters per minute(2.5" water rise = 5" of water) @ 2200rpm,
76 L/Min (3.5" rise) @ 2500rpm
85 L/Min (4.5" rise) @ 2800rpm.
Worn engine that needs rebuilding are roughly double i.e.
126 L/Min(10.5"rise) @ 2200rpm
152 L/Min(14.5"rise) @ 2500rpm
170 L/Min(17"rise) @ 2800 rpm
The valves could also be out of adjustment.
Another way, same idea, is to block the blowby tube with a 1/2'' pipe nipple with a cap that has a 15/64 hole drilled in it. Use 3/8'' id looped clear tubing with water in it slipped over the oil dipstick tube. Use sharp tipped felt marker to mark the water level with the engine off, have someone start an already warmed up engine and run the rpms up to 2.2, 2.5 & 2.8k rpms. Mark each water level with the pen, measure then multiply each by 2.
This is all very simple to do, just hard to explain with words.
The following 6 users liked this post by Whit:
12vChapa (12-12-2011), beerbellykelly (02-23-2011), dandiesel (10-20-2015), daveO (01-15-2011), EasternAggie (03-26-2011), RAW (01-15-2011) and 1 others liked this post. (Show less...)
Old 01-15-2011, 05:31 PM
Whit's Avatar
Site Mascot
I miss Bill Fleming.....one of the greatest mechanical mind I have ever known
thanks for the contribution Bill
The following 2 users liked this post by Whit:
12vChapa (12-12-2011), dandiesel (10-20-2015)
