Dodge Ram Front Fender Replacement
Old 03-23-2010, 09:16 PM
dan33klein's Avatar
Default Dodge Ram Front Fender Replacement
hey guys im about half way through the body work on my 96 dodge. i need to get her all painted up before summber vacation rolls around. woot woot gunna be a big senior next year at the high school , anyways im replacing both front fenders. i have the replacement clips that you buy for around 180 each. i just dont see how its attatched to the truck. i see all the bolts on top of the clip that are under the hood. and the one down by the rocker panel. how else is this fender attatched? who has all replaced these fenders? how to do, and tips would be great. need to stop chasin the girlfriend down the halls and start getting some work done on this thing
Old 03-23-2010, 10:05 PM
Sagefisher's Avatar
I just did my drivers side one on my 96 and it took awhile as I had to remove everything mounted to the inner fender. I had some help with it but the bolts I did I had to remove the battery tray and there was three bolts under there and then at the front behind the headlight there was 6 bolts. to access these I took the whole headlight assembly out. I think it was three 10mm screws to remove that. I also removed the plastic fender liner (plastic push pins) and under the fender liner you can see a 14mm? bolt that you have to get from under the truck facing upward, this is at the rear of the fender sort of where your brake pedal is(except on the outside) then there is the one at the rear of the fender lower right by the door. I found it helpful to use the bolt holes on the new fender to locate the ones that needed to be removed.
BEFORE you install the new one make sure you have any brackets off the old one first!!!
Good luck to you count on a few hours on the first one.
Chris
Old 03-23-2010, 10:25 PM
dan33klein's Avatar
alright thanks alot. so i need to remove the battery aye? i have to take off the front bumper and headlights anywho , but thanks alot for the help. i suppose same goes for passenger side?
Old 03-23-2010, 10:31 PM
Sagefisher's Avatar
Yes almost the exact same but the passenger side is easier as it didn't have nearly the amount of items mounted on the inner fender. Give the old fenders a good look before mounting the new ones to ensure you have all brackets to bolt too. on the drivers side I had the ABS mounts that I forgot until the fender was mounted.
Old 03-23-2010, 10:36 PM
dan33klein's Avatar
oh boy , i didnt receive the passenger one yet, is it cut out for the antenna?
Old 03-23-2010, 10:41 PM
Sagefisher's Avatar
Mine was cut out and almost the exact fit
Old 03-24-2010, 12:33 PM
PhilipR's Avatar
There are a couple threads in here about it.....I have done 3 trucks now. The aftermarket replacement fenders DO NOT have the inner fender. You have to drill or cut out the spot welds that hold the inner fender to the outer fender. I can do them in a couple hours now.
Old 03-24-2010, 03:39 PM
dan33klein's Avatar
thats good less work
Old 03-24-2010, 11:09 PM
oglejust's Avatar
less work? u have 2 weld them back in
Old 03-25-2010, 06:48 AM
monster12valve's Avatar
yup i am doing mine now also...when you take out the plastic wheel well cover there is a ton of tack welds that hold it to the inner fender... i didnt have to take off my bumber though.... just check fitment 3,000,000,,000,00,000 times before you tack it back in.. clamp it in place and shut the hood and door and make sure the gap is right then burn her in
Quick Reply: Dodge Ram Front Fender Replacement
