03 6.0 cranks but no start
Old 04-30-2010, 10:53 AM
rtaggs's Avatar
Default 03 6.0 cranks but no start
my 03 f-550 6.0 all of a sudden won't start. it cranks ok, and has good battery voltage. it has a new icp sensor, with good readings, about 1.2 volts while cranking, it needs a minimum of .8 or .9v to start. so this leads me to believe my hpop is ok. also i checked the ficm, i have 47.2v with key on and it calls for a minimum of 45v. the fuel filters are new as is the fuel pump/filter assy(stripped drain plug). it sounds like there is a suction at the little filter when pump runs. it did this before and after i changed filters and pump. i have looked for cracks in the cap with a magnifying glass, nothing that i can see. i've seen threads on here about cracked caps, but no updates on what happened. i'm thinking it's a fuel issue. if anyone has any ideas i'd really appreciate the help. thanks, ron
sorry. it's an 04 not 03.
Old 04-30-2010, 12:17 PM
12vcummins96's Avatar
hmmm everything is on can you spray some wd 40 in the intake and get it to fire off
Old 04-30-2010, 05:09 PM
Take the secondary fuel filter out of the bowl and turn the key to make sure you're getting fuel up to that point.
Old 05-03-2010, 08:09 AM
rtaggs's Avatar
it does pump to the bowl. i checked that. oh, also forgot to mention it has no codes.
i just retested to make sure there was fuel to the secondary filter bowl.. i drained it and then turned key on. it filled up but with tons of bubbles, so i'm thinking there has to a leak somewhere.
Old 05-03-2010, 08:12 PM
Sure sounds like it. Did you change filters recently? I've heard of the frame mounted unit giving troubles not seating properly. Some guys said you'd never notice it unless you had a fuel pressure gauge though. I'd pop that off, make sure the filter is properly seated, and put some oil on the rubber o-ring to make it go on easier and try reseating it. Couldn't hurt.
Stupid question but have to ask... you do have fuel in the tank right?
Old 05-04-2010, 06:42 AM
rtaggs's Avatar
i filled the tank because i thought i might have a leak on the pickup tube in the tank. when the pump runs and then turns off i hear bubbles at the tank. i took the breather out of the tank, and i see bubbles. the fuel pump, filter and cap are new. i can't figure out where it could be sucking air.
Old 05-05-2010, 05:46 PM
PJB007's Avatar
That system runs on a high pressure oil pump to open the injectors. And when was the last time you changed the oil. I just replace my injector regulator for the same problem but I could spray into the intake to start. Just wont stay running .
Old 05-11-2010, 10:42 AM
rtaggs's Avatar
i was totally off on this one. i finally took it to the dealer and it was the ficm.even though it tested good for me, it was still bad.
Old 06-12-2010, 01:51 AM
frpman55's Avatar
my ac caused mine not to start try removing belt and see if it starts.it was due to low rpms
Old 06-12-2010, 04:56 PM
Karls03's Avatar
My rig was cranking not starting and getting fuel, it was a little 10A f'in fuse between the two stacks of 3 relays in the interior fuse panel! I even bought an FICM due to the code.
Quick Reply: 03 6.0 cranks but no start
