fuel pressure sensor
Old 05-27-2010, 08:27 PM
ztk7220's Avatar
Default fuel pressure sensor
where do i but my fuel pressure sensor for my gauge pics would be awesome
Old 05-27-2010, 08:59 PM
94 12valve's Avatar
I just installed a T fitting for mine.
Old 05-28-2010, 06:50 PM
ztk7220's Avatar
a T fitting on the main fuel line or what
Old 05-28-2010, 09:13 PM
cumminspwr11's Avatar
ya i would like to know also, i put mine on the top of the filter housing, the out-side that goes to the injection pump- is that a good location?
Old 05-29-2010, 08:02 AM
94 12valve's Avatar
yes, I put it on the feed line right before the injection pump
Old 05-29-2010, 06:31 PM
dan33klein's Avatar
drill and tap the banjo bolt
Old 05-29-2010, 07:43 PM
on the P-7100 inlet...go with 1/8" NPT
Old 05-29-2010, 08:28 PM
i put on of the valve stem things that come on the newer 24vs on the outlet on top of the fuel filter housing and then ran a 12" braded line with sender on the end of it
Old 05-30-2010, 03:52 PM
94 12valve's Avatar
here is mine
Old 05-31-2010, 12:26 PM
mylilpwny's Avatar
i know summit and i think jegs sells in line adapters with the tap already there ... something along these lines ... idk if it will work for our trucks tho .. some one will chime in and say yes or no ...
Summit Racing SUM-G1711 - Summit Racing® Fuel Pressure Gauge Fittings - Overview - SummitRacing.com
Quick Reply: fuel pressure sensor
