oil pressure sending unit
Old 06-03-2010, 01:12 PM
96blackcloud's Avatar
Default oil pressure sending unit
anyone have a picture showing where this is located? i think its on the driver side of the block right back from the timing cover is this correct? i bought a new one to cure my possessed oil pressure gauge
Old 06-03-2010, 01:46 PM
Your right. Drivers side - its kind of hard to reach.
zdanman (01-13-2011)
Old 06-03-2010, 02:22 PM
thanks great picture by the way i saved it to my files just in case hahah
Old 06-03-2010, 02:34 PM
There is a lot of info like this on Fritz's Dodge Ram Tech
Its all there - you just got to look.
Old 06-21-2011, 08:27 PM
zdanman's Avatar
It will be located either behind the power steering pump or infront of the fuel heater depending on where they wanted to drill it at the factory. Mine was infront of the fuel heater.
To replace it on a 98 you need a 1-1/16" Oil Pressure Sender Socket (long deepweld) for the new sensor. Advanced Auto carries it. The old one you just break off the plastic part and use a regular 1-1/16" socket.
You can get it at genos garage for $35+shipping.
Durtyd09
11-11-2015 01:43 PM
purnell82
07-22-2015 10:42 AM
jhprice
03-29-2015 09:36 PM
powerstroke4178
11-27-2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
10-01-2014 06:27 AM
Quick Reply: oil pressure sending unit
