how do i reset the fuel filter light?
Old 06-21-2010, 09:04 PM
JS2TZU's Avatar
Default how do i reset the fuel filter light?
I changed my fuel filter and the light on the dash still comes on. Is there a trick to resetting the light like the change oil filter light?
thanks in advance!
Old 06-21-2010, 09:22 PM
wildbill's Avatar
If it's like resetting the change oil light: with the key on-engine off, press the accelerator pedal to the floor 3 times.
Old 06-21-2010, 09:45 PM
Benjamin's Avatar
Bombardier
FUEL FILTER LIFE RESET
This message will appear when a reset is performed either by using the steering wheel controls or the following manual procedure.
For vehicles with steering wheel controls, press and hold the select button for five seconds while the FUEL FILTER LIFE message is displayed. This message will appear on the DIC for ten seconds.
For vehicles without steering wheel controls, do the following:
Without pressing the pedals, turn the ignition key to the on position without starting the engine.
Wait five seconds.
Completely press the brake and the accelerator pedals simultaneously and hold for ten seconds. The system is now reset.
Turn the ignition key off.
The next time the engine is started, the message will no longer be displayed.
also note that the "select button" is the "return arrow" and is on the right side of the steering wheel.
hope this works for you.
The following 2 users liked this post by Benjamin:
chuckyl (07-20-2011), tjorve (07-31-2011)
Old 06-21-2010, 10:01 PM
JS2TZU's Avatar
thanks dude that did it my truck is without the steering controls
jeffersonl
11-15-2015 07:35 PM
ctjkelley
06-03-2015 06:01 AM
RatsMC
05-04-2015 05:25 PM
moneypitk5
02-12-2015 11:01 AM
jeffersonl
10-25-2014 06:46 AM
Quick Reply: how do i reset the fuel filter light?
