Rear end... dually vs single ?
Old 06-27-2010, 08:33 AM
angelic0-'s Avatar
Default Rear end... dually vs single ?
can anyone get me pictures of both ?
i'm thinking about doing a dually conversion and one guy told me i didn't have to swap rear ends... :P
Old 06-27-2010, 12:11 PM
tltruckparts's Avatar
to do it right you need to swap rear ends. but ive seen it done without changing rear ends. its all about the backspacing of the wheels. and i believe someone out there makes a hub adapter for the dually wheels
Old 06-27-2010, 08:33 PM
angelic0-'s Avatar
how much difference is there in cm or inches ? dually rear is wider ?
Old 06-27-2010, 08:39 PM
12vcummins96's Avatar
its better just to swap them out
Old 06-27-2010, 09:03 PM
iker42's Avatar
its enough of a difference, an inch or two. Swap axles. You'll be happier in the long run, plus you'll probably get a Dana 80 outta the deal.
Old 06-27-2010, 10:53 PM
HAYMAFIA's Avatar
and the dually rearend is a direct bolt in. i have done one myself
Old 06-28-2010, 10:20 PM
85_305's Avatar
Being Evaluated
Why wouldn't you just BUY a diesel? it's gonna be a lot of work (and work that you will never get your money back outta) to swap in the axle, the new tires, spacers, and the fenders. And the truck still wont be a 1-ton like any other dually on the road just because you swap rear axles and fender flares
Old 06-28-2010, 11:01 PM
HAYMAFIA's Avatar
the only difference in the 2500 and 3500 is the rearend. same frames, motors, trannies. the 2500 does have smaller calipers but that is easily changed too. i made a 2500 into a dually and if he already has a single wheel and he knows this truck then why would he trade it for a dually that he knows nothing about.
Old 06-29-2010, 11:17 AM
85_305's Avatar
Being Evaluated
1-tons have better suspension too. And I'm not sure for these EXACT trucks, but typically they have better cooling, better trans/gearing, etc.
Old 06-29-2010, 01:06 PM
cumminspwr11's Avatar
i have a 95 2500 and 96 3500, they are they same except for the rear ends and the beds, same 3.54 gears, same leaf springs, same motors, etc. the 3500 does has overload springs, the only draw back to making a 2500 into a 3500 is that a true 3500 will be able to legally haul more due to dif. numbers on the cabs vin tag
Quick Reply: Rear end... dually vs single ?
