HX40 turbo?
Old 07-05-2010, 01:34 PM
Killacams's Avatar
Default HX40 turbo?
so i was thinking about buying a HX40. does anyone one know if there good or how much psi they get. i know stock ones get 35psi
Apwcu (08-04-2010)
Old 07-05-2010, 08:00 PM
dan33klein's Avatar
i say 40psi. depends what you buy, a regular hx40 i believe has the 57mm wheel.
i have a super 40 that has a 60mm wheel.
it might be better to get a hybrid or convert yours.
depends what other mods you may want to do
Old 07-05-2010, 10:01 PM
Killacams's Avatar
the one im going to get is a 60mm. and i see you have sdx injectors where did you get yours at?
Old 07-05-2010, 11:31 PM
tltruckparts's Avatar
sdx injectors come from sdx theyre a sponsor on here. i had an hx40 before my phatshaft. i would have to say spend the extra couple hundred and get a little bitter turbo so you dont have to upgrade twice. i hated my hx40 only had it for 3 or 4 months before finally gettin a 62/65/14 best investment i ever made
Old 07-06-2010, 12:25 AM
jrad989's Avatar
i wanted an hx40 for a while but heard too many horror stories about them. they are a weaker turbo. so i decided to save for somethin higher quality.
Old 07-07-2010, 03:04 PM
SSpeeDEMONSS's Avatar
if youre going to get a 40 get a super 40. also need to remember that you cant bark it a lot or you are going to snap a shaft.
like previously stated, spend more now to get a better charger and not have to spend even more. it really depends on what exactly you want to do with the truck.
Garrett
Old 07-07-2010, 03:45 PM
JIT's Avatar
JIT
JIT is offline
You get buy a new wheel and front cover for your HX35 to make it a 60mm. I would do that before buying an HX40. The shaft will be the weak link and like mentioned before it will break if you bark it too much.
Old 07-07-2010, 05:06 PM
dan33klein's Avatar
get a phat shaft!
Old 07-14-2010, 07:54 PM
blackout94's Avatar
i had one that barked at 40 psi a couple times held up but dusted it lasted 3 months of abuse.
im not sure you will like the spool up tho with as little fuel as you have
Old 08-03-2010, 01:35 AM
chokeonmismoke's Avatar
i dont like em trust me been threw alota turbos the past few months jus save ur money and get a good one
Quick Reply: HX40 turbo?
