VW Diesels Discussion of all things Volkswagen Diesel - TDI, Bug , Touareg , Jetta , Golf , Passat
1.6L N/A Turbo kit!
Old 07-26-2010, 12:33 AM
thirdstreettito's Avatar
Default 1.6L N/A Turbo kit!
$450 Complete Turbo Conversion for 1.6 NA Engines. Includes TDI intake manifold, TDI exhaust manifold, TDI Turbocharger and TDI Downpipe. Oil Lines Not Included. VW Diesel TDI
My uncle(25 year diesel veteran)buys from this guy, says the parts are cheap German parts. I haven't had any experience with him, but for the price, I'd give it a shot.
Also, either of these intercoolers could probably be modified to fit up front somewhere.
$120 New Turbo Intercooler for 99-05 Golf and Jetta TDI and 1.8T. VW Diesel TDI
http://www.dieselvw.com/3B0145805DIntercooler.htm
Last edited by thirdstreettito; 07-26-2010 at 12:34 AM. Reason: Automerged Doublepost
Old 07-26-2010, 09:34 AM
Deezel Stink3r's Avatar
Be careful- the 1.6l N/A engine has some major internal differences.
- no oil jets for the pistons
- weaker con rods
- different (weaker) non hypereuretic pistons
- different (smaller) injectors with an release pressure of 138bar instead of 150 to 158bars
- depending on output several different cams: the more power the later the intake opens and the earlier the exhaust closes
- different exhaust valves to withstand higher heat
You might trim the 54hp engine to some more horses. But the fun is not for long as the parts will not withstand the higher pressure
The intercooler shown is not worth to be plumbed in. The huge unit of the Mercedes Sprinter does cost the same and is a direct replacement, bigger as the radiator itself.It has a net size of 31" and the same height as the radiator. It is the most common used intercooler for tuning the VW's in germany. Bercause it is cheapo and offers outstanding performance.
The original 1.6lTD can be boosted up to 120hp- but expect a head gasket fail every three month. Cracks will develop between the intake and exhaust valve and ruin the head.
To run that power stable you need an added air/oil cooler.
Old 07-26-2010, 11:31 AM
zrock's Avatar
ya what he said... I have seen a guy localy turbo his jetta and has blowen it up 2x now in less than 4 months...
Old 08-02-2010, 01:38 AM
Ditto. There is far more to the German engines than adding a turbo.
Old 09-16-2010, 09:47 PM
seandonato73's Avatar
i buy from that guy a lot hes good shipping is a little slow sometimes but the parts are cheap..... any way i have a 1.6 td and you should see the list of different stuff, diff heads and the works. better off swaping engines from a factory td
Old 10-05-2010, 06:39 PM
doonboggle's Avatar
Originally Posted by thirdstreettito
[url=http://dieselvw.com/16TurboConversion.htm]$450 cheap German parts
Try 'cheap chinese' parts....!!
Old 02-15-2011, 05:01 AM
trav1856's Avatar
Well in all honesty, would this be so bad, as long as you didn't drive it like a teenage idiot? The power's there if you need it, but you don't have to live with your foot in the turbo.
also, why not install a waste gate as well?
Old 08-29-2022, 01:54 PM
willslife77's Avatar
the link doesnt work, im looking for a turbo for my VW Rabit with a 1.6.
Old 08-30-2022, 07:08 AM
Herkybc130's Avatar
Don't waste your time with this turbo. Had it on my 81 Rabbit. Blew the rings out after a year. I'm almost done with swapping in a 2004 TDI. Much better way to go. That being said, if still interested, let me know. There is a significant amount of fabrication required for this turbo kit to work.
avatardvr
18
08-08-2019 12:38 AM
Strictly Diesel
Strictly Diesel
09-17-2015 05:11 PM
Finn92
02-24-2015 10:41 PM
n2brk
02-21-2015 09:05 AM
GreenDieselF
10-20-2014 02:05 PM
Quick Reply: 1.6L N/A Turbo kit!
