Truck Shaking Real Bad
so i got the overdrive solenoid fixed put new tires on it and new transmission mounts and i still have this vehicle shake from 40mph up. its really bad between 40-55mph then tapers off but you can still feel it....thought it was tires being in bad shape so i replaced them, still the same problem, thought it may be in the powertrain so i found the tranny mounts squshed and mushy rubber, replaced and still have same shake. dont know which route to go, read about driveshafts being out of balance but how likely is that? shocks shot and so im getting leaf spring bounce? leaf spring bushings? motor mounts? bent axle? balljoints? bearings? dont know if any body else has had a problem like this or not i just dont want to throw parts at it and sink a lot of money in it. read some other threads similar but not really describe what going on with mine. it is 4 wheel drive
ok, so i checked it out and the wheels fit snug with the lug pattern so that is correct, all lugs are conical. Took all wheels off, and retorqued using proper torque sequence. Still shaking haha. guess i will start with the cheapest parts and work my way foreward, like leaf spring bushings. Tell me what you guys think about this....if the shocks are wore slap out in the rear, would that cause is to shake? its almost like a side to side shake and you can feel it coming on and it starts to get harder and harder almost like everytime it bobs back it springs it to the other side and each time it slings harder and harder....am I thinking right or am i completely wrong. Havent pulled the shocks off yet to see.
