2 Micron Filter?
Old 10-17-2007, 11:45 PM
madmanwithmouse's Avatar
Default 2 Micron Filter?
Any one know where to get one that fits in the stock housing? If not, has anyone used the 2 micron fither/water separator, with a fass pump? Sure seems to me the dodge has dropped the ball on filtraion seeing how the injectors were made for 2, but yet they have a 7. I found out the other day that chevy has a 3 in thier turcks. I also heard that dodge is coming out with a 5, but relly .... comon jeesh.
Link to kit \/
http://www.puredieselpower.com/catal...it-p-1273.html
Old 10-18-2007, 09:12 AM
Wyatt Earp's Avatar
You are correct filtration is the key.
They used to make (I'm sure they still do) a oem drop in element that is 2um.
I'm not sure I would use it though as it will be pricey and will plug quickly which in turn can startve a truck of fuel. Admittedly that is more for a VP44 truck and not yours but I think you see my point.
I have the 144, the 12 and a 6 under the hood on my FASS set up.
Old 10-19-2007, 08:29 PM
well im planing on getting a 2micron filther kit then feeding it with a fass pump. Im sick of losing injectors due to abrasion. **** I just put ALL SIX in, so I want to keep them new.
Old 10-23-2007, 10:25 AM
steved's Avatar
Baldwin makes a 5 micron drop-in filter for our trucks...that's about the best one I have heard of for a while.
I run a HF6604 on the FASS...it is rated at 3 micron, but is actually 99.5% @ 5 micron, 98.6% at 3 micron (absolute), and 95% at 1 micron...and that is at 30 gallons per MINUTE, so it is effectively more efficient at our lower flow rates (95 gallon per HOUR on the FASS 95/150).
I know guys have used Cat filters in the past (1 or 2 micron) with good results...they usually place them between the OE filter and the injection pump. These tend not to affect flow or pressure because they are physically BIG.
The 2 micron Racor filter some guys use on the water separator side of the FASS is not recommended because it isn't designed for suction, and you can starve the FASS...not to mention it is only rated at 90GPH IIRC.
steved
And if you are referring to the Perma-Cool fuel filter, if you read the adds, they trap particles AS SMALL AS 2 micron...even a screen door will catch a 2 micron particle once in a while...
With the HF6604 FASS filter, you would essentially be filtering to around 1 micron, then running it through a 2 micron filter...the second filter wouldn't really do much.
steved
Old 10-23-2007, 08:38 PM
Thanks Ill have to look into that.
Old 10-26-2007, 05:47 PM
Larry@DPP's Avatar
Diesel Performance Products (FASS) has the FF-1003 Fuel Filter 3 Micron (Fass 150) for the long filter system and a short filter version coming soon. Also, I spoke with Dan at DPP today about the fact that the systems come out of the box with a filter that is not as fine as the OEM 7 micron and when a guy gets the FASS system the first day he needs to upgrade the filter to match or improve the filtration of the OEM system. He told me that in the near future this will change and they will be including a finer filtration filter than OEM in the kit right out of the box.
Any DPP (FASS / HPFP) dealer should have these on hand for you or be able to get them drop shipped from DPP without any trouble.
Larry
Old 10-26-2007, 05:54 PM
A definitive answer from the source. Thanks Larry
Old 10-26-2007, 06:55 PM
DangerousDuramax's Avatar
Link to kit /
Here ya go.
www.nicktane.com
And yes, it can be modified to fit the Dodge. Several have already done it.
Old 10-26-2007, 10:32 PM
humm...
In that case I might just go with a complete fass system.
I was thinking of useing a case IH filther for a 9370 but, havent been able to find the specs yet.
The fass setup has the filthers on the suction side?
The guy at the shop where they replaced my injectors told me that the fass system bypasses the stock filther.?! Also that to make sure to order it with the 5micron filther other wise it would come with a 10. Does anyone know the specs of the mount thread size, O-ring dimeter, ect...?
Old 10-27-2007, 09:35 AM
Larry@DPP's Avatar
Teh FASS system has the water seperater first, the fuel filter second, and the pump third. The filters are on the suction side. You cant really order a FASS system with a 5 micron because they are packaged with the FF-1010. Your dealer may be able to get a different filter in the box if he special orders that way with Dan, but I've never tried that one with him.
Yes, the FASS system completely elliminates the OEM filter. The fuel lines go from tank to FASS system, go from FASS system to injection pump. Your OEM fuel line that goes from the filter to the injection pump will be laying there dead beside where your blue rubber line from the FASS system goes into the new banjo bolt. You gain a vent line into the fuel tank...... the old fuel supply line.
Larry
Quick Reply: 2 Micron Filter?
