Potential Diesel Owners Forum Questions and discussions for potential diesel owners *FOR POTENTIAL OWNERS ONLY*
Best truck for under $5000?
Old 08-31-2010, 05:55 PM
U375D's Avatar
Default Best truck for under $5000?
Hello-I need some help regarding truck buying
What's the lowest price for a used 3/4 ton 4x4 diesel? I only have 5k to spend on it, and craigslist isn't really giving me a good idea. Might just be where I live.
I don't care about any brands, bed size, cab size, engine type, it doesn't matter.
The only requirements would be dual airbags and not completely rusted through
Any help? I live in the midwest
Old 08-31-2010, 07:14 PM
CSIPSD's Avatar
Dual air bags would be a Superduty, or 2nd gen Dodge...
You should be able to find a few, there going to be very high miles for that price...
Old 09-05-2010, 02:07 AM
Jizzle's Avatar
You had me until dual airbags.
I bought an ex-military blazer, and I love it!
You may have a few kinks to work out as these trucks are 20+ years old, but you should be able to find one for ~$2k if you look. If you get the military truck (not sure the civilian term for this one), it's actually rated at 5/4 ton. No typo there, 5/4 ton, so if that's important to you, I'd look into it.
Good luck.
Old 09-05-2010, 02:22 AM
tiremann9669's Avatar
I guess that depends on your definition of a 2nd gen Dodge, my 96 only has drivers side airbag, I think passenger ab came out in 98. I paid 4300 for mine with 190k and some body rust
Old 09-23-2010, 06:22 AM
monster12valve's Avatar
bought mine for 3k with 240k and little rust.
were in the midwest do you live? i could find you something if your within driving distance of the cleveland area.
Last edited by monster12valve; 09-23-2010 at 06:22 AM. Reason: Automerged Doublepost
Old 09-23-2010, 07:32 AM
gunman41mag's Avatar
Moderator
I sold my FORD 1999 F-250 7.3 PSD SUPER-CAB LONG-BED with 141,000 miles NO RUST for $4,000
Old 09-26-2010, 10:44 AM
Jakemd98's Avatar
the 5/4 ton is a CUCV. There's a lot of different variations, but standard they are a 6.2L non turbo motor, turbo 400, NP208 or 205 (depending) transfercase, 14 bolt rear with a detroit locker and 4.56 gears, and a Dana 60 front, some fronts came with a Limited slip depending on it's package. they can be had with low miles and clean body for around $3k.
Max speed is roughly 55 on these trucks, you can get close to 70mph with a 35-36" tire. The pulling capability is limited due to the motor being a dog, But these trucks are solid mechanically and make great candidates for a 12v swap and OD trans.
Old 10-02-2010, 05:59 PM
Woody35's Avatar
get a late 90's 6.5. it has airbags and there not as bad as people say they are.
Old 10-14-2010, 10:50 PM
12vcumminspower's Avatar
i just found a 1996 dodge cummins 12v 5 speed manual for 5000 with 200K which for a cummins really is just breaking in you just have to be patient and look around and talk to people
Old 10-15-2010, 08:42 AM
Jakemd98's Avatar
just have to be careful with that kind of mileage on a 12v. the motor is fine, it's the transmission and front end components. if it has never had the front end gone through and freshened up then it may turn into a money pit
Quick Reply: Best truck for under $5000?
