Dana 80 dually
Old 10-18-2010, 01:39 PM
MechanicalDiesel's Avatar
Default Dana 80 dually
Has any one on here put a dana 80 dually rear end on 2500 to make it a dually 2500? if so how hard is it and how much modding is needed?
Old 10-19-2010, 12:08 AM
tiremann9669's Avatar
I've been thinking about the same thing, just not sure if anything is different besides the rearend and the box
Old 10-20-2010, 06:44 AM
I would assume it shouldnt be to hard, it would be pretty sweet though. Im guessing it would be just like having a 3500
Old 11-22-2010, 06:05 PM
joshbaker's Avatar
the dana 80 is narrower
Old 11-22-2010, 07:22 PM
Fairmont's Avatar
I was told that drw dana 80 is 2 inches wider than a srw dana 70
Old 11-22-2010, 09:49 PM
HAYMAFIA's Avatar
if your truck had a single wheel dana 80 then the dual wheel dana 80 is a direct bolt in. the cab and chassis rearend is narrower.
Old 11-23-2010, 06:23 PM
blazier18's Avatar
im thinkin about doin the same thing but dont wanna buy fenders
Old 11-23-2010, 08:30 PM
scarecrow's Avatar
a dually dana 80 from a regular dually will bolt in to a 2500 truck. a dually dana 80 from a cab chassis will not work. SRW and DRW beds are the same so you can order dually sides and bolt em onto a SRW bed however you will need to cut your wheel well larger. for the front if its 4x4 all you will need are the dually spacers you do not need the whole axle.
cummins.1.5.3.6.2.4
09-20-2015 01:47 AM
tractormandan
Wanted To Buy (WTB) - Used
05-09-2015 08:44 AM
scrnnmssuck
For Sale
03-20-2015 11:55 AM
joseywales
01-16-2015 08:44 AM
gyayo2012
11-15-2014 08:11 PM
Quick Reply: Dana 80 dually
