low boost code
Old 10-31-2010, 01:30 AM
pushingmy6.0's Avatar
Default low boost code
so today i got a low boost code on my sct.. now what do i do??
i also was hiting 40 psi on the boost the other day.. that can not be good??
Old 10-31-2010, 10:58 AM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
Check your map sensor first. Make sure the hose is still connected on either end and no rips.
Also make sure you didn't loose a boot.
Old 10-31-2010, 02:42 PM
Despite what the code says, how is the truck running?
Old 10-31-2010, 09:11 PM
truck is runing good.. i was check just for the hell of it an the code showed up.. so i check it again an it didnt show up.. turbo needs to be cleaned, but other then that.. its runing good
where is the map sensor??
Old 11-01-2010, 08:32 AM
Jagsdiesel's Avatar
The map sensor is mounted to the cab over by the heater and a/c box. It is a block sensor with a hose and connector coming off of it. The hose goes to the passenger side of the intake manifold.
Old 11-01-2010, 01:25 PM
ok, ill take a look around there... thanks!!
jagsdiesel. is this josh?
Last edited by pushingmy6.0; 11-01-2010 at 01:25 PM. Reason: Automerged Doublepost
Old 11-02-2010, 08:38 AM
doin my own 6.0's Avatar
I had a low boost code show up on mine, I think that if you happen to lug the engine down, then put your foot into it, the turbo can't spool up fast enough to catch up to the engine demand. the map sensor see's that and will throw a code, IF you do this several times. where you towing or just driving. I live in the mountains and some times when I go to pass someone I have to make sure my rpm is at least 2k or higher other wise it will throw the code. but not always light the MIL. because I have a way to read codes now every once in awhile I put my computer on the truck just to see whats up and low and behold there it is. i think it's a p0701 low turbo boost. I've cleaned my turbo it wasn't real bad but it still does it???? maybe I have a weak map sensor.
Old 11-03-2010, 12:51 AM
i dont tow.. yes when im driving, ill jump on the gas an it works just fine then ill let off and drive down the road and then ill jump on her again.. junked up!! i know she needs to be cleaned out.. im starting to think i should just get a new one....
it loads up alot.. is that due to me driving like a gal??
Old 11-03-2010, 08:13 AM
Jagsdiesel's Avatar
Yes the name is Josh.
utting around is not the best for it by anymeans. But the EGR and he oil breather are the worst for it. Once those are gone you'll be good to go once the turbo is cleaned and possibly a new vgt solenoid.
soco
07-27-2015 06:06 PM
Saams69
07-20-2015 11:21 PM
flash7210
07-05-2015 09:25 AM
chen
05-29-2015 04:34 AM
cameronlee51
10-28-2014 12:33 AM
Quick Reply: low boost code
