86 f250 bolt pattern to 92 f250 ? will they swap ?
Old 11-04-2010, 02:49 PM
reddog1701's Avatar
Question 86 f250 bolt pattern to 92 f250 ? will they swap ?
Hello I have 86 f250 want to swap wheels and tires to 92 250 ? thanks
Old 11-04-2010, 05:41 PM
FordDZLMan9191's Avatar
They'll fit. If I remember right, Ford had the 8 on 6.5" bolt pattern from the late 40s-early 50s up to 97-98. GM and Dodge still have it so it want rims from them, they'll usually fit too. 99 and newer Ford use a 8 on 170mm pattern and they don't fit.
Old 11-04-2010, 06:50 PM
reddog1701's Avatar
right on thanks Dzl man
Old 11-08-2010, 10:47 PM
Sycostang67's Avatar
The wheels will swap, ford used the same 8 lug pattern up until late 98.
The full float axles ford used have a larger center hub than chevy/dodge and the OEM wheels wont fit over it.
Old 11-09-2010, 01:07 AM
So does that mean that factory GM aluminum rims wont fit my truck? A buddy of mine just bought an 03 GMC Dirtymax and it has the GM rims that I like and have always wondered how they'd look on a Ford. He said this coming spring I could probably have them, but if they wont fit...
Old 11-09-2010, 03:43 PM
DieselCrawler's Avatar
u can go to town with a carbide bit and open the center hole out. i had h2 rims on my 86, had to remove a 1/8 inch or so from the center hole to fit.
Old 11-09-2010, 03:56 PM
Did you ever have any problems after doing that? Was it real hard to keep it a round hole?
Old 11-09-2010, 05:34 PM
wasnt to hard. the lugnuts center the rim to the hub, so reallt the hole can be a little off and still work. it isnt hub centric. look at any aftermarked rim, the hole is loose over the hubs.
Old 01-07-2011, 02:52 PM
rico.mtltire's Avatar
i know i'm posting in an old thread, but i just wanted to inform you that if you hone the hub hole yourself the next time you get tires put on and balanced you will have a hard time balancing them, most shops don't have the adapter that holds the wheel to the balancer by the bolt holes, 90% of the machines clamp the rim to the machine by the hub hole and if it is off center you will never have a proper balance.
Old 01-07-2011, 03:09 PM
balanced? wtf is that?
Quick Reply: 86 f250 bolt pattern to 92 f250 ? will they swap ?
