looking to relocate om617 oil-filter housing...
Old 11-05-2010, 06:37 PM
mr_manny's Avatar
Default looking to relocate om617 oil-filter housing...
Currently In the middle of installing this motor into my fj40 (early toyota landcruiser).
would love to replace the housing completely...with a modern spin-on filter solution.
found a examples online, please see attached.
any other options?
thanks,
manny
Attached Thumbnails looking to relocate om617 oil-filter housing...-oilplate4.jpg   looking to relocate om617 oil-filter housing...-oilplate5.jpg
Old 11-05-2010, 08:10 PM
ben2go's Avatar
Check superturbodiesel.com - tuning performance turbo diesel mercedes, W123, W116 and up. OM617, OM60X and the Mercedes section of www.4btswaps.com Most people fab their own and use AN fittings, braided SS hose, and a regular remote filter adapter.
Old 11-05-2010, 09:17 PM
FTE's Avatar
FTE
FTE is offline
It is not a good idea to replace the factory oil filter with a "modern spin-on". The benz unit is not only a main and bypass filter but thermostatically controlls the flow through the cooler. This is way better than a single spin-on, if you need to move for clearance then just remote mount the facory unit. What trans are you planning on using in the FJ?
Old 11-07-2010, 08:14 AM
External oil cooler thermostats are available for around $50.
A cooler must be installed though and it needs a thermostat set for over 212*f.
Old 11-07-2010, 10:42 AM
mr_manny's Avatar
sounds like the best option if to make an adapter that allows me to relocate the stock housing...
found the following example:
FTE,
tranny is a sm465:
made possible w/Luke's kit (4x4labs.com):
thanks for the replies,
manny
Old 11-07-2010, 11:33 AM
FTE's Avatar
FTE
FTE is offline
Hey looks great! I see you also have the motor with the cali emissions although yours has already been deleted. I kind of like the turbo mounted up high, and the intake looks like it flows better. I like your FJ! Keep us posted.
Old 11-08-2010, 04:23 AM
Worse actually, the air has to make two hard right turns instead of flowing straight in.
Old 11-08-2010, 08:36 PM
mr_manny's Avatar
Regardless of number of turns, I'll bet you guys will be able to see the grin on my face...the day I drive her home
as always, thanks for the info.
Old 12-24-2010, 01:15 PM
mr_manny's Avatar
With the help from a few friends, I know have an adapter made from 5/8" aluminum...really happy with how it turned out
Used a gasket, as a template:
will be using 1/2NPT to AN8 fittings
final trimming:
test fit:
the biggest reason for my oil-housing relocation was due to a parking brake cable interference...no longer an issue
Old 12-24-2010, 01:38 PM
ben2go's Avatar
Great job on whittling that piece out.Give me a few days and I'll have one filed out of aluminum.
Quick Reply: looking to relocate om617 oil-filter housing...
