Diesel Auto Power Visit - Diesel Auto Power
under/drive, gear splitter, can be overdrive starting bid $300
Old 11-29-2010, 11:09 AM
jkidd's Avatar
Default under/drive, gear splitter, can be overdrive starting bid $300
Willing to sell out side of ebay:thumbsup:
Bought this to make my 6 spd a 12spd, Ended up swapping gears. I regret not doing the 12spd.
Gear Splitter for manual trans 28% reduction/ underdrive. Has straight 1:1 ratio as well so you can use it on a 4x4 if you just use 2wd.
Can be rebuilt for 28% OVERDRIVE for $400 more. Designed for 20,000lb GVWR.
Product is in good condition and had been gone through before I received it.
estimated reduction for towing with the under drive engaged:
4.10-->5.25
3.73-->4.77
3.55-->4.55
3.07-->3.92
Contact me at jacobk@sent.com
Local pick up in Riverside or can transport along the I-15 up to SLC for a small fee.
Mitchell Underdrive 28%, Gear Vendor, US Gear overdrive - eBay (item 300498014119 end time Dec-02-10 14:12:04 PST)
search terms
gear vendor, overdrive, under drive, US gear, eaton
