94 turbo 7.3 no start or starts and dies no restart need help
Old 11-29-2010, 07:01 PM
tkazanecki's Avatar
Default 94 turbo 7.3 no start or starts and dies no restart need help
This truck has 200,000 miles runs great 1 day the next may start right up run for 1 minute or so and dies like key was turned off. Will not start again for a little while 10 minutes or so then does the same thing. Or it may not start at all the first time. There is fuel in the filter every time I check it. I am not really up on the computer controls so dummy terms will be best for me. Any help will be appreciated.
Old 12-01-2010, 09:58 PM
fordornothing's Avatar
it might be the Cam Position Sensor. (CPS) or a failing High Pressure Oil Pump (HPOP). is it a "powerstroke" or just the "turbo diesel"?
Old 12-02-2010, 06:42 AM
tkazanecki's Avatar
Default 94 F250 power stroke
Thanks for the advice the truck is a powerstroke the cam sensor I know where it is the high pressure oil pump coul you tell me more . Is there a test I can do to check cam sensor?
Old 12-02-2010, 12:03 PM
to my knowledge, no. just replace it. there is/ was a recall from ford for it. the HPOP. is at the front of the engine on top. it's in the bottom of the valley. the HPOP isn't a cheap part. on Diesel performance parts and accessories. Diesel injectors, pumps, filters, kits, additive, gauges and apparel.. it's $400.
Old 12-02-2010, 12:52 PM
PSD's Avatar
PSD
PSD is offline
Check all of your wire and connections. They tend to melt sometimes. Ive had the IPR wire melt which causes my no start issue. Ive also had a UVCH pigtail melt. Check my no start thread for more info
Old 12-05-2010, 01:53 PM
tkazanecki's Avatar
Default the cam sensor fixed the problem Thank you
If a guy wanted to body lift this truck 94 f250 powerstroke what would you recommend . I am thinking about a 4 inch
Old 12-05-2010, 06:16 PM
do a suspension lift. it looks better. not as gay as a body lift.
Old 12-05-2010, 06:22 PM
99stackedpowerstroke's Avatar
on a body lift you dont want more than 3 inches cause then the body gets to far from the frame and easier ta roll and twist body off cab, go suspension
dshopex4
Chevy/GMC Duramax 01-04 LB7
14
04-15-2015 09:40 PM
Quick Reply: 94 turbo 7.3 no start or starts and dies no restart need help
