2004 duramax lly will crank but wont start
Old 12-03-2010, 10:40 PM
erics1983's Avatar
Default 2004 duramax lly will crank but wont start
I have a 2004 Chevy Duramax LLY 6.6 turbo diesel that will crank but wont start. Will on run ether. Checked all fuses and they are good. Checked glow plugs and are working. Injection box is working. No DTC's. Repaired wiring harness above alternator on passenger side. Replaced fuel pump filter and water sensor. Fuel rail pressures are good. Need help to figure out why it wont start.
Old 06-02-2011, 09:05 PM
bamaboy's Avatar
try replaceing fuel filter housing
Old 06-02-2011, 09:23 PM
2009RavenR1's Avatar
Will the truck prime if you pump the primer? Does it ever get hard? And stop spraying ether into the truck before you break it from the motor running away!!!
Old 06-02-2011, 10:10 PM
Rttoys's Avatar
This thread is 7 months old, I'm sure he's fixed it somehow by now.
Old 06-02-2011, 10:12 PM
well... ****
Old 06-03-2011, 09:14 PM
Rttoys's Avatar
ish1521
08-26-2015 08:42 PM
ronstop
02-26-2015 09:48 AM
HKLBRY
02-18-2015 09:46 PM
HKLBRY
02-17-2015 08:52 PM
musikagod
11
11-30-2014 07:22 AM
Quick Reply: 2004 duramax lly will crank but wont start
