2003 dodge wont start.
Old 12-10-2010, 06:53 PM
dodge crazy's Avatar
Default 2003 dodge wont start.
My 2003 dodge cummins wont start when its cold and hot. I dont no what to do. So, if any one has some good ideas or has had the same problem let me no what to do.
Old 12-10-2010, 10:30 PM
Blue01cummins's Avatar
does it crank??
Old 12-11-2010, 11:44 AM
zach_west's Avatar
does it sound funny when you crank it? what codes is it throwing. My 03 wouldn't start cold or hot. turns out all 6 injectors had worn out. how many miles are on it? clamp the return line and see if there's high pressure fuel coming down the return because that usually is injectors.
Old 12-27-2010, 05:09 PM
It dont sound funny when i crank it over. I have good fuel pressure. It dont want to fire. But once you get the truck running it runs good and then you can restart the truck as long as it dont sit no longer than a hour and a half. If you dont restart it before then your back to trying to get the truck runin. i have 200,000 on the truck now. but, she still runs like new other than startin. Also, it is not throwing any codes at all. thats what gets me.
Old 12-27-2010, 05:15 PM
cummin_un_glued's Avatar
FormerVendor
how are you checking the fuel pressure?....how are you getting it to start back?...long cranks or starting fulid?....is it a stick shift? if so will it roll start when it wont start off of the key?...i'm thinking possibly the injectors are leaking by....when it does start does it rattle at first?.....have you checked the return flow on the injectors?
Old 12-29-2010, 06:24 PM
I have 16 pound of fuel pressure. Yes it does run rough when you first start it. Yes it does crank over. Once you run the truck and it gets up to temp it will restart but im sure thats do to the heat in the motor. I have not checked any of the injectors yet. But, im workin on geting the truck to a shop and hookin up the computer. Im not shur about these newer motors, i have always worked on 80's style cummins in semi's. But, this motor in my truck is a hole nother ball game. Im not good with computer operated stuff. So, if ya all can give me some good idea's of what to check before going to the shop im more than willen to do it. I dont have no problem workin on trucks. Thats my job.
Old 12-29-2010, 06:35 PM
farmboydiesel's Avatar
03 cummins injectors are **** iv replaced two sets in the same truck for a friend couple years back
Old 12-29-2010, 06:57 PM
FormerVendor
unless the CEL is on a computer diagnostic isnt really gonna be alot of help other then compairing commanded rail pressure to actual rail pressure but even then its still up to the mech to figure out why they dont match
Mac1997
07-13-2015 05:08 AM
PeteBug
5.9L 24V Performance
05-23-2015 01:17 PM
irozchris
03-14-2015 11:16 PM
rschriek
01-26-2015 07:30 AM
elkmaniac
10-29-2014 07:01 PM
Quick Reply: 2003 dodge wont start.
