Boost Elbow
Old 01-15-2011, 11:39 AM
Smoke 'em's Avatar
Default Boost Elbow
Ok, i just installed an adjustable boost elbow this morning, and was expecting to see a lot more boost, but i got nothing It doesn't matter if the adjustment screw is tightened all the way or backed all the way out, im only getting 22-24 lbs of boost... Am i doing something wrong? What should i check, and what kind of boost should i be seeing???
Thanks Guys
Old 01-15-2011, 12:03 PM
01cummins13's Avatar
what did you have before you installed the elbow? do you have a leak somewhere?
Old 01-15-2011, 12:04 PM
Default Re: Boost Elbow
Is your truck stock?
Luke
Old 01-15-2011, 12:30 PM
RAW's Avatar
RAW
RAW is offline
Pinch off the wastegate hose and go for a rip. See if you cant make more boost. If you can't, thats all your truck has.
Old 01-15-2011, 12:45 PM
Smoke 'em's Avatar
I was already boosting 22-24 before i added the elbow
And yes its fairly stock, fass and a power puck thats it...
Old 01-15-2011, 01:08 PM
RAW's Avatar
RAW
RAW is offline
If your making the same boost as before there may be a wastegate issue. The linkage to the waste gate may not be adjusted tight enough, and is always open a little. It's a possibility.
Old 01-15-2011, 02:57 PM
He may not have enough fuel to increase boost.
Luke
Old 01-15-2011, 07:27 PM
24vcumminscowboy's Avatar
i put the elbow on my pickup and 20 is max for me normal driving towing i can push it up 28 and thats with stock fueling im thinking of plugging my wastegate hose just to see if i get any difference
Old 01-16-2011, 10:52 AM
Smoke 'em's Avatar
So it shud boost more with my SDX 100's once i install them that is
Old 01-16-2011, 11:00 AM
RAW's Avatar
RAW
RAW is offline
Correct, boost is directly related to fuel. The difference between stock and my 65's was 7psi more boost.
Quick Reply: Boost Elbow
