TC LOCKUP SWITCH SCHEMATIC (REPOST)
Old 01-23-2011, 09:56 AM
zdanman's Avatar
Up TC LOCKUP SWITCH SCHEMATIC (REPOST)
This is a repost of the diagrams of my previous thread which were somehow deleted
94 - 95 TC LOCKUP
Originally Posted by TST Products
Install ground wire from the pin 54 orange wire with black stripe to a switch or relay such that the ground source can be turned on and off. The pin 54 orange wire with black stripe is located in computer connector located on the firewall behind the air cleaner.
http://www.tstproducts.com/Torque Converter Lockup Switch.pdf
Originally Posted by cumminspwr11
a 94 is the 3pin 47rh tranny and its easy pizzy compared to the 47re, on the rh you have a three pin connector on the tranns, the middle is 12v power in, the two on either side control lock-up and od, you could put switches on both-mine has a switch for each and i love it, the tranny will only lock in 3rd and od with a stock vb, you can put it in lock up at 25-30mph and it will bump u up to 3rd and lock-up right away-this bogs down some motors, i find my truck is faster be rapping 2nd out and then hitting lock-up
RAW (05-16-2012)
Old 01-23-2011, 10:33 AM
RAW's Avatar
RAW
RAW is offline
They were not deleted, but move to an archive. They will be posted soon into the Tech article section.
Old 01-24-2011, 04:19 AM
zdanman's Avatar
thxs i was wondering what was up
Old 05-06-2012, 11:55 AM
soot for life's Avatar
Hey guys! whats the risk of running a lock up switch?
Old 05-06-2012, 03:09 PM
zdanman's Avatar
None. Just remember to unlock it when slowing down or you will stall (since once locked in... will not come out of overdrive until unlocked).
Old 05-16-2012, 06:21 PM
STDiesel59's Avatar
Hey i was just wondering if i install a lock up switch with it off would it still lock up like normal or no? thanks for your help!
Old 05-16-2012, 06:26 PM
RAW's Avatar
RAW
RAW is offline
Sure will.
Old 05-16-2012, 06:50 PM
STDiesel59's Avatar
Awesome! Thanks for yuor Help!
Old 05-21-2012, 05:31 PM
JBearSVT's Avatar
Will it still upshift, or do you have to already be in the gear you intend to stay in when you switch it on?
Old 05-22-2012, 04:16 PM
captain_stabbin's Avatar
yes it will up shift
Quick Reply: TC LOCKUP SWITCH SCHEMATIC (REPOST)
