Cummins swap to a 1500sport
Old 01-25-2011, 10:00 AM
Tpaine22's Avatar
Question Cummins swap to a 1500sport
Cummins guys, how hard is it to swap a cummins into a gaser dodge 1500 sport? What all does it take?
Also what does it take to swap a duramax with a cummins? I'm tryin to find a cummins to put in my chevy.
Old 01-25-2011, 11:32 AM
dodgecummines12valv's Avatar
will man the gas truck it will take a lot of work you will have to change rear end in it cuz that gas rear end cant hold the power and i thank also you will have to make the frame stronger. and idk about the chevy
Old 01-25-2011, 05:56 PM
thebullet83's Avatar
just get a 2500 sport and put 1500 badges on it. i've heard it being done before, but...
Old 01-25-2011, 08:07 PM
BriteWhiteRam's Avatar
Why do you want to take a duramax out and put a cummins in??? your not going to gain anything
Old 01-28-2011, 09:22 AM
GuyWithA24Valve's Avatar
You're going to gain a better engine
Just messin, but the cummins into a 1500 would be pretty costly. So would the cummins into a duramax. All depends on how much you want to spend
Old 01-28-2011, 10:56 AM
You would spend more trying to swap a cummins into a duramax truck, then modifying it for power then it would cost you to just build the duramax up, that's why I asked, heck you could probably build a 7.1 stroker for the cost to swap a cummins and get the allison to work..... but hey its not my money
Old 01-28-2011, 11:32 AM
Dieseldan36's Avatar
Originally Posted by Tpaine22
Tpaine22's Sig:
2002 black duramax 2500hd 4x4, 4 inch lift, turbo back straight pipe, Bullydog triple dog tuner on tow mode (unless a ricer needs some smoke in his windows), blacked out windows, next bomb, tranny upgrade, twin turbos, so on and so on
Twin Turbos?? an you wanna take an put a cummins in?? Keep yer dirty max, an if your already runnin twins keep building. No point in swappin a cummins in.
As far as putting a cummins in a 1500 its not really worth the time and effor youll have swappin parts!
Old 01-27-2013, 07:14 PM
mac5733's Avatar
Default i
i have seen alot of people asking the same question... what do you need/how hard is it/ can you put a 24v cummins in a 1500 dodge ram? and quite frankly no one have answered it. So my question is... (besides costing alot or "not worth it") can someone answer the original question please? i have a 97 1500 ext cab thats lifted and is fully loaded but it doesnt have a motor or trans, and i also have a 98.5 24v cummins with low miles but the body it really messed up and its a base line truck. i want to take the drive train out of the 98 2500 and put it in the 97 1500. what do i have to do and how hard is it?
Old 01-27-2013, 07:18 PM
RAW's Avatar
RAW
RAW is offline
Diesel Bombers - View Profile: angelic0-
He has done this, and his truck is in a couple TOTM contests.
Old 01-23-2014, 08:16 PM
01ramoffroad's Avatar
Yes it can be done because I did it. I started with a 2001 1500 and bought a wrecked 1999 24v Cummins. The frames are all the same on second gen dodges from 1500-3500. Basicly what you have to do is have a complete donor truck and swap everything including your axles. So its either that or just swap the bodies out its your choice and depends on how much work you want to do
Quick Reply: Cummins swap to a 1500sport
