2003 Ram 3500 Front Wheel Joints
Old 01-26-2011, 10:37 PM
Sphinxj13's Avatar
Default 2003 Ram 3500 Front Wheel Joints
Anyone know how to remove the front wheel joints? Does the axle have to come out or what? The hub is seized up and not coming off either and not sure how to get it off without ruining it...Any ideas or thoughts?
Old 01-27-2011, 12:57 PM
redcummins04's Avatar
There's videos on YouTube of the removal. Type in dodge ram hub removal or ball joint installs something should pop up easier to watch then type.
Old 01-27-2011, 10:22 PM
Sphinxj13's Avatar
Well the issue is that I can't get the hub off...I know how to it's just seized up and won't come loose...I had all 4 bolts out and the put the tire back on and lowered the truck onto that tire to use the trucks weight and yet it still didn't even move even with having no bolts in it.
Old 02-05-2011, 04:54 PM
haulitrite's Avatar
Thread the four bolts back into the hub about half way them use a punch and a hammer on the bolt heads to push the hub assembly out.
Old 02-06-2011, 02:36 PM
tn hillbilly's Avatar
Do a search on hub removal. Most guys use the trucks power steering to push it out. Hope this helps.
Marshall
Old 02-06-2011, 10:43 PM
Sirwrenchiezolot's Avatar
Marshall
What he said i used a big mega slide hammer and slamed it a million times then i put a bolt in partialy and used a socket and extension and pined it agianst the frame turned the wheel and it poped out. then i i wished i never would of used the mega hammer.
Old 02-07-2011, 04:16 AM
dieseldude03's Avatar
I used a large gear puller, but ONLY to put tension on it while bashing it with a BFH (Big Friggin Hammer). Has worked real well the few times I've done it. If you try to use only the puller, you'll likely pull the hub in two and they're not real cheap.
Old 02-08-2011, 03:34 PM
1AMatt's Avatar
Site Sponsor - 1aauto
This way usually works best for me. The worst that will happen is you damage one of the bolts, you can buy bolts at any hardware store though. A chisel and a hammer between the hub and knuckle works if its not on there too bad. A slide hammer will work too, but if your bearing is on its way out, I have ripped them in half before
06-22-2015 12:40 PM
bubbs33003
05-03-2015 11:31 AM
99RAMS
Tire, Wheel & Suspension
01-25-2015 11:31 PM
jstoshick
For Sale
10-02-2014 10:24 PM
dieseldude03
For Sale
10-02-2014 07:53 AM
Quick Reply: 2003 Ram 3500 Front Wheel Joints
