7.3 mpg
Old 02-03-2011, 12:06 PM
wisakowsky's Avatar
Default 7.3 mpg
Has anyone found a good way to get the mileage better on a 7.3? Appreciate the help..
Old 02-03-2011, 05:39 PM
95powersmoker's Avatar
You have stage 2 injectors and are asking about fuel economy? What are you seeing now when you drive respectively?
Old 02-04-2011, 04:36 PM
wisakowsky's Avatar
around 14, i think if i put my stock turbo wheel back in i will get a little better. I have a ats houseing with the wicked wheel or what ever its called.
Old 02-05-2011, 01:15 AM
Jeff Davis's Avatar
Mine is completely stock and back when everything was in good working order, and keeping my foot out of the throttle and under 2000rpm mine was at an average of 20 to 22 mpg. just some info of what they are capable of. keep in mine arizona and everything is flat here.
Old 02-05-2011, 07:31 AM
gunman41mag's Avatar
Moderator
I was getting 15.5 MPG out of my 1999 F-250 7.3
Old 02-05-2011, 10:50 AM
PHPDiesel's Avatar
Sponsor
Drive slower. Put a 2x4 under the accelerator pedal. Never exceed 2000 RPM...EVER...
Run stock size tires or narrower at max. inflation pressure. Make sure your alignment is dead-on (toe is most important for mileage). Buy a cheap early-90's car for a commuter.
Old 02-05-2011, 01:48 PM
articfox's Avatar
i get 20mpg about in nc its hilly here but keep it under 600 etgs n under 2000 rpms anything over will kill your mpg drop the stage 2 n go to stock ur milage will go up
Old 02-05-2011, 11:14 PM
I have a 00' and avg around 15-17 on a daily basis. When I turn the tunrs to stock I get much better.
Old 02-05-2011, 11:50 PM
Some good advice there.
Old 02-06-2011, 08:23 AM
tmcclure's Avatar
my 2000 7.3 gets 14.4 mpg and i have a fairly heavy foot!
bbilt
5.9L Rotary Performance
05-29-2015 07:05 PM
01-14-2015 03:40 PM
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
11-29-2014 12:40 AM
dba
11-26-2014 10:28 AM
Omingnome
10-20-2014 12:25 PM
Quick Reply: 7.3 mpg
