Clutch firewall Repair kit?
Old 02-21-2011, 11:30 AM
R.Cassidy's Avatar
Default Clutch firewall Repair kit?
Does anyone know where i can get a firewall repair kit for my 97 stroker? When i push down on the clutch the whole clutch assembly moves on the fire wall so im thinking that is the problem not the actual clutch.
Old 02-21-2011, 12:13 PM
fordornothing's Avatar
when you say clutch assembly, i'm assuming you mean the master cylinder? i don't think they make a repair kit so the best you could do is get a peice of 14 ga. steel and make up a backing plate on the engine side of the fire wall. does your brake master cylinder move when you push on the brake pedal?
Old 02-21-2011, 02:46 PM
R.Cassidy's Avatar
i havent looked my buddy looked for me when i pushed in the clutch and yes the master cylinder moved cuz it was a ranch truck and isnt in the best shape. I heard they make a kit to repair that. but if not ill have to do what u said.
Old 03-06-2011, 11:21 AM
97dieselnewb's Avatar
or go to a junk yard and cut the fire wall out of the same truck and theres a perfect patch panel, it will probably run you ten bucks, and be a better fit then an after market patch panel
Old 03-08-2011, 09:36 AM
R.Cassidy's Avatar
i never thought of that thanks man! she is a fixer upper so i cant wait to get her running
Old 03-08-2011, 01:09 PM
DieselCrawler's Avatar
i know a repair kit is made for them. ford no longer offers it. let me see if i can find the link...
Terrapin Manufacturing
i am sure it could be made to fit, says only to 91 but the cabs are the same, just some stuff under the dash is different and firewall plugs are different.
Last edited by DieselCrawler; 03-08-2011 at 01:09 PM. Reason: Automerged Doublepost
Old 03-13-2011, 08:16 PM
R.Cassidy's Avatar
Bad *** man thanks!!
Old 02-17-2012, 11:16 PM
j1mmy's Avatar
i read that the trucks had a problem,and ford made a stiffening plate to fix it, but ford had taken care of the problem and reinforced the firewall by 92,so the repair was no longer needed.. all it was is a second steel plate that bolted on to strengthen the wall.. i heard it on line, cant swear ether way..
Strictly Diesel
Strictly Diesel
09-17-2015 05:11 PM
Turbo67
07-25-2015 02:26 PM
kryz9903
07-02-2015 06:14 AM
klu408
Price Quote - Request A Price
04-26-2015 07:28 PM
slowstroke
For Sale
03-27-2015 05:19 PM
Quick Reply: Clutch firewall Repair kit?
