6.5 heads
Old 02-26-2011, 08:05 AM
muderxtreme's Avatar
Default 6.5 heads
Does anyone know or have tried either double stacking head gaskets or de-stroking a 6.5 to run more boost. I've done it before with small blocks to run turbos and stuff but I dont really know much about the 6.5s and was thinkin about it when I rebuild mine
Old 02-26-2011, 09:55 AM
92typhoon937's Avatar
well i dont think u can double stack head gaskets i dont think that would work out to well
there may be thicker gaskets available im not sure though
Old 02-26-2011, 01:11 PM
Woody35's Avatar
thats more of a cheater way to lose compression. if you run too much boost and too thick of gasket you have the risk of blowing the headgasket
Old 02-28-2011, 03:05 PM
Ya I know its the cheater way but it was just a though. How about destroking a 6.5, anyone heard of that? Or even if you could stroke one by using a different crank like a 400 crank in a 350 sbc.only reason I'm asking is because I kinda want something different than the normal.
Old 02-28-2011, 03:17 PM
93chummins's Avatar
If you want to know what you can or can't do to a 6.5td talk to Bill Heath at heathdiesel.com He has at least 20 6.5td and some run as high as 35psi boost
I am currently running 15 psi boost with no mods and no problems
Old 02-28-2011, 06:06 PM
2MuchJunk's Avatar
You can't stroke or destroke a 6.5 with out offset grinding a crank. The 6.2 and 6.5 share the same stroke. You don't wan't to lower compression because it moves the top of the piston further from the pre chamber and hurts its ability to function properly.
Old 02-28-2011, 08:59 PM
Alright then, I was just curious because I've done it with other motors but never a diesel. thanks to everyone for their imput
Old 03-03-2011, 01:14 AM
gmguy's Avatar
gm does make different thicknessof headgaskets
greatlakes diesel
02-13-2015 09:55 PM
detroitdiesel idi
12-27-2014 10:03 PM
Snoobly
12-11-2014 11:59 AM
bdemutis
12-07-2014 01:36 AM
bdemutis
11-28-2014 08:16 PM
Quick Reply: 6.5 heads
