351 to 7.3 swap
Old 03-15-2011, 09:38 PM
Bucky Hughes's Avatar
Default 351 to 7.3 swap
any one know how hard and wat needs to be changed to put powerstroke in a 97 f250 with 351 engine I no I need to change wiring harness fuel tanks rad and rad support does the trans bolt up??
Old 03-15-2011, 09:56 PM
97dieselnewb's Avatar
whats it going in? will it even physically fit? and you'll probably need to beef up the suspension, to support the extra weight
oh and the trans, and rear end to support all the torque
Last edited by 97dieselnewb; 03-15-2011 at 09:56 PM. Reason: Automerged Doublepost
Old 03-15-2011, 10:03 PM
its in a 97 f250 4wd i no itll fit just wat needs to be changed to make it work
Old 03-15-2011, 10:07 PM
prison's Avatar
suspension to hold it. possibly the inner cab harness/guage guage cluster and light bezel. possible rear axle, possibly t-case, transmission definitely, possibly front axle if 4x4. radiator support radiator, wiring. and you might find another thing or too ya need along the way
Old 03-15-2011, 10:19 PM
95powersmoker's Avatar
Engine, transmission, harness, PCM, IDM...
Old 03-15-2011, 10:27 PM
have you got the engine yet? I know of one thats complete with the heads off because it was smoking and the guy thought he could fix it, now he is in over his head, but it was runnin before it was pulled
Old 03-15-2011, 10:42 PM
Ive been looking at a few but nutting bought yet how much? wat year? wats all there?
Old 03-16-2011, 12:15 AM
100 bucks, PM sent
Old 09-30-2011, 01:04 AM
did u do that swap yet? i did a 97 7.3 int to my 92 bronco. its not hard.
Old 09-30-2011, 05:23 PM
fordornothing's Avatar
try to find a rolled truck. then you have all you're wiring and everything there.
lvnlrge63
08-23-2015 09:57 PM
boylesjesse
04-08-2015 10:11 PM
ReckONE
Diesel Engine Conversions
02-25-2015 09:41 AM
Dunn
99-03 7.3L Performance
10-26-2014 01:44 PM
wisakowsky
10-14-2014 08:13 PM
Quick Reply: 351 to 7.3 swap
