smoke screw
Old 03-29-2011, 07:45 PM
staylorw250's Avatar
Default smoke screw
is the starwheel screw and the smoke screw to different screws I tightened the screw on the top of the pump and I didn't notice it smoking anymore then normal the spring is out of the afc housing. with that spring out will the smoke screw not effect anything with the spring out. I am just looking for a little smoke to have fun with at school not to **** anyone off. right now it just puffs a lil bit I don't want to mess with the full fuel screw untill i have gauges
Old 03-29-2011, 07:53 PM
jdbigblue12v's Avatar
what year is your truck? i know that after they came intercooled in 1991.5 the injectors became smaller, which will cause it not to smoke as much as the older ones. i have a 1993 and i am able to get smoke from turning the fuel screw 2 turns in and starwheel 1/2 of a turn.
Old 03-30-2011, 12:29 PM
Default smoke screw
mine is a 89 non-intercooled the screw i turned was on the top of the afc housing t-25 screw and a 13mm lock nut i turned it all the way in and i never got anymore smoke.
Old 03-30-2011, 01:48 PM
1989w250's Avatar
This will give you a good bit of smoke. At the end of the vid he explains how to get SMOKE
mattshow123
14
03-12-2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
10-06-2015 10:54 AM
carid
Diesel Bombers Sponsors
08-13-2015 05:49 AM
Fred427
06-29-2015 09:43 AM
gagemotors
06-09-2015 04:24 AM
Quick Reply: smoke screw
