Lift pump upgrade
Old 03-29-2011, 09:20 PM
89_torquer's Avatar
Default Lift pump upgrade
I have read the sticky on what Cummins part numbers and the procedure to change out the factory 1st gen lift pump, but are there other solutions?
I was thinking a low pressure electric pump or an electric pump with a regulator. If this is a valid approach, does anyone know the flow rate needed to support something lets say 300 to 350hp? 110gph or higher?
Thanks for any help.
Old 03-30-2011, 11:38 PM
chromehound's Avatar
Alot of guys run Holley blue or black (or similar). The blue I ran would run 12psi at idle.
Old 03-31-2011, 02:12 PM
89_torquer's Avatar
Is there any advantages/disadvantages with going to something like the Holley blue pump?
Can you use this style gasoline pump with diesel?
Old 03-31-2011, 05:11 PM
1989w250's Avatar
My friend that worked for cummins said 13 psi.
Old 03-31-2011, 05:21 PM
I ran a blue for 9 months before I sold the truck, 1 buddy has been running one for over a year and another has run a Speedyway version for a long time.
The blues are fine but the others may need to be regulated so as not to mess things up, I think its anything over 15 or 17psi is hard on seals so if your electric pump is below that your good unregulated.
Old 03-31-2011, 06:31 PM
89_torquer's Avatar
That seems like a more cost effective option than upgrading to the cummins mechanical version in the sticky.
landon025
09-08-2015 09:21 PM
dieselgang
Ford Powerstroke 99-03 7.3L
08-29-2015 04:04 AM
Renteria1217
04-16-2015 11:38 PM
moneypitk5
02-12-2015 11:01 AM
CJJD4640
9
02-09-2015 07:22 AM
Quick Reply: Lift pump upgrade
