HELP...START AND IDLE FINE, FUEL FILTER LIGHT COMES ON DURING ACCELERATION...DIES
Old 04-01-2011, 08:12 PM
91 7.3 DUALWHEELER's Avatar
Default HELP...START AND IDLE FINE, FUEL FILTER LIGHT COMES ON DURING ACCELERATION...DIES
7.3 IDI STARTS AND IDLES OK...BUT WHEN I TRY TO DRIVE DOWN ROAD FUEL FILTER LIGHT COMES ON AND ENGINE DIES......SEEMS LIKE ITS SUCKING AIR, NEW FUEL PUMP, NEW INJECTOR PUMP, NEW RETURN LINES...NOW WHAT?
Old 04-01-2011, 08:39 PM
tiremann9669's Avatar
Sending unit ?
Old 04-01-2011, 08:48 PM
Question
NOT SURE HADNT THOUGHT OF THAT...WHERE IS IT LOCATED?
Old 04-01-2011, 10:37 PM
DieselCrawler's Avatar
in the tanks.
also just cause it is a new pump doesnt mean anything. need to check fuel pressure at the fuel filter. should be around 7 psi.
Old 04-06-2011, 07:38 PM
OK THANKS GUYS...OH AND IVE READ MANY OF YOUR POSTS CRAWLER...THANK YOU FOR ALL THE VALUBLE INFO.
Old 04-06-2011, 07:44 PM
95powersmoker's Avatar
Welcome to Diesel Bombers, Stick around, there are some very knowledgeable guys around here willing to share their information.
By the way, It's easier on the eyes if you type without CAPS all the time...
Old 04-06-2011, 11:17 PM
no problem bud, i love these trucks, will be IDI for life. haha.
Old 04-11-2011, 07:25 PM
More problems..leaking fuel from heating element on top of filter housing...replaced o rings but fuel leaking through the middle of plastic..just ordered new one..set back $180...still seems to be sucking air..could it be in crossover for the dual tanks?
Old 04-12-2011, 09:59 AM
there is no crossover for the tanks. get all your leaks fixed first. any leak, feed or return side, will cause air intrusion and running issues.
jeffersonl
11-15-2015 07:35 PM
ctjkelley
06-03-2015 06:01 AM
Gm3500
05-07-2015 11:01 AM
moneypitk5
02-12-2015 11:01 AM
jeffersonl
10-25-2014 06:46 AM
Quick Reply: HELP...START AND IDLE FINE, FUEL FILTER LIGHT COMES ON DURING ACCELERATION...DIES
