Neutral Safety Switch Location
Old 04-03-2011, 02:50 PM
Krokus_96F350's Avatar
Default Neutral Safety Switch Location
I'm looking to by pass the neutral safety switch on my 96 F350. I can't find it. I was told to look between the clutch pedal and the floorboard but it's not there. On the tranny the only wires I see seem to go to the backup lights.
Anyone know where the switch is located? To bypass it, once I find it, can I cut the wires and twist them together?
Thanks for reading, and any possible help.
Old 04-03-2011, 04:51 PM
fordornothing's Avatar
it should be under the dash on the clutch pedal. itlooks like the brake switch.
Old 04-03-2011, 05:49 PM
I just went out again and looked and didn't see it. There is nothing electrical even remotely near the clutch pedal or linkage. I have the new part here, so I can see what to look for.
Guess I better invest in a Manual..... and better glasses.
Old 04-23-2011, 02:13 PM
MatieA's Avatar
It is on the pushrod for the master cylinder, between the clutch linkage and the floorboard. I would post a picture, but I am not home right now.
Old 04-25-2011, 07:20 PM
codyawise's Avatar
its on the push rod from the clutch linkage that goes into the firewall
Old 07-14-2011, 05:00 PM
R.Cassidy's Avatar
so what do u do to start ur truck when the clutch is broke? im gettin my 97 running and im gonna get it to run before i fix whatever is wrong with the clutch. how do i start it with no clutch? the guy i bought it did it but i couldnt see what he was doing underthere.
Old 07-15-2011, 11:21 PM
codyawise's Avatar
i have a switch with wires running to the terminals that are wired with the starter its located right behind the passenger side battery. rig up that on off switch or even push button and have the key in the run position before flippin or pushin that switch
Old 10-28-2013, 01:32 AM
Wow, 2 1/2 years since I started this thread.... I like the picture, it helped me find what I was looking for, well not find really. My truck had the switch removed and wires taped up. After replaceing the Clutch Master Cylinder and Slave Cylinder last week, I added the Safety Switch too.
cumminspwr11
12
10-17-2021 03:50 AM
08-13-2015 10:10 AM
cumminsp12v
24
04-20-2015 12:05 AM
Ryans71
Diesel Engine Conversions
12-24-2014 08:47 AM
IslanderXJ
12-17-2014 04:14 PM
Quick Reply: Neutral Safety Switch Location
