Diesel in my coolant tank?
Old 04-05-2011, 08:54 PM
racerdave's Avatar
Default Diesel in my coolant tank?
I just checked my coolant and found it FULL of diesel fuel? The truck was running fine when I shut it off. its got 230.000 miles on it and hasnt givven me any trouble. What do I do to fix it? Cost if I do the work myself? I just got laid off this couldnt come at a worse time!!! ugh
Old 04-05-2011, 08:55 PM
CSIPSD's Avatar
I see a 2008 F-550 as your truck? Or do you have a 7.3?
Diesel in the coolant is a cracked injector cup or lifted injector cup.
Old 04-05-2011, 09:38 PM
racerdave's Avatar
NO sorry, the 550 was a truck the I drove in Afghanistan (armored) which is how I found this forum. I own and drive a 2002 350 with a 7.3. Do I have to pull the heads off to fix this? I heard a horror story about the cab having to be pulled off a ford truck to get the heads off? Im hoping this isnt my truck...
Old 04-05-2011, 09:58 PM
BIG NIG's Avatar
there is a special tool to removal/install tool to do them with the head on
its ford 6.0 that the cab or engine needs to come out get the heads off
Old 04-05-2011, 09:59 PM
95powersmoker's Avatar
No need to pull the cab on our trucks...
And no you do not need to pull the heads off to fix an injector cup. You need to remove the valve covers, pull the injectors and the cups are what the injectors sit in. I do believe you need a certain tool to get the injector cups out but CSIPSD would know way more about that than I do.
Old 04-05-2011, 10:10 PM
BIG NIG's Avatar
the tool looks like a big tap you screw into the cup where the injector sits and you pry them out
the install tool looks like a injector, red loctite if i recall to hold them in
need to drain the coolant and fuel system before removing the cups
Old 04-06-2011, 09:21 AM
flathead jack's Avatar
delco diesel okla city ok charged me 600.00 to fix mine you can buy a tool from whitaker for 300.00 goto their web site for inj cup removal tool and utube watch him do it
Old 04-06-2011, 10:48 AM
I think Clay @ RiffRaff has the tool you need and the cups as well.
Old 04-06-2011, 11:23 AM
Wattson's Avatar
From where can You order new cups to change them?
Old 04-06-2011, 11:40 AM
CSIPSD's Avatar
Give RiffRaff Diesel a call, thats where I get most of my maintance stuff from, because he packages it just right so I can carry it with me...
Riffraff Diesel: Motorcraft Injector Cup
Quick Reply: Diesel in my coolant tank?
