05 f-450 engine slowly dieing and shuts down ?
Old 04-18-2011, 11:12 AM
72fj's Avatar
Default 05 f-450 engine slowly dieing and shuts down ?
72fj here, have 6.0 o5 engine slowly dies,no fault codes hooked up fuel psi gauge and run engine till engine dies.fuel psi staying up not the problem any info would greatly app!!! thank you 72fj!!!!!
Old 04-18-2011, 12:18 PM
MUDSTROKIN''s Avatar
Is it dying after the engine warms up?
Old 04-18-2011, 04:30 PM
72fj's Avatar
Default 05-f450 slowly dieing!!!
yes after it starts to warm up it slowly dies out ,with scaner hooked up high psi pump pressures staying to spec.....
Old 04-19-2011, 08:13 AM
After it's warm and it dies, will it start back up? What's the High pressure pumps numbers while cranking if it doesn't start back up?
