2001 cummins oil leak?!?!
Old 04-22-2011, 10:07 PM
Redneckcummins's Avatar
Default 2001 cummins oil leak?!?!
2001 24v cummins
my entire under carriage was coated in oil so i cleaned it all off to find out where the oil is coming from and i think i narrowed it down to the front left (drivers) side of the block right behind a pulley....any help?
Old 04-23-2011, 03:41 AM
TugBoat's Avatar
Not coming out of blow by tube?
Old 04-23-2011, 07:30 PM
no it looks to be coming out the bottom of the crankcase
Old 04-23-2011, 08:54 PM
Laster's Avatar
Do you still have the factory bottle for crank case attached? It can cause oil to get everywhere once it reaches the fan. Just a thought.
Old 04-23-2011, 09:53 PM
TugBoat's Avatar
Ck the front cover and pan bolts? Maybe behind the vac or vp ?
Old 04-23-2011, 10:07 PM
RAW's Avatar
RAW
RAW is offline
Very popular for the gasket between the Vac pump and timing cover to leak. Mine did, and it looked like a front crank seal leak by the way the fan was throwing it around. I ended up pulling my fan off and running the engine to pinpoint the leak.
Old 04-28-2011, 07:28 AM
at first it was leaking on the drivers side now the drips are all on the passenger side?!
Old 04-29-2011, 01:39 PM
cam899's Avatar
its most likely to be the vac pump thats where mine was 250 dollar fix havent seen a drop since
Old 04-29-2011, 02:31 PM
RAW's Avatar
RAW
RAW is offline
$250??? Get a shop to do it I assume?
Old 05-05-2011, 07:20 PM
so i think i found the leak after $35 and 3 hours at the car wash......a loose bolt
Quick Reply: 2001 cummins oil leak?!?!
