Gears = mpg???
Old 05-01-2011, 08:09 AM
Chilly7's Avatar
Default Gears = mpg???
I'm running a 99 Drw and getting about 14.5 mpgs with 355 gears. I have two buddies that have the same truck running 410's and they get 20 mpgs. I find it hard to believe. Yeah it takes more to get mine going but is it really that big of a difference? Should I swap to 373's.? What is the best setup for this truck?
Old 05-01-2011, 09:25 AM
MPG also has a lot to do with driving habits, gear ratios, tire size, transmission and many other things. I had a 01 6spd speed with 3.55's and my buddy had an 01 Auto with 4.10's. Bone stock he usually got 1-2 mpg better than I did. But I am also 32 yrs old and he is 57 yrs old. Our driving habits are totally different.
Now if you do much towing you will like 4.10's or a higher gear ratio.
Old 05-01-2011, 09:27 AM
turbo20psi's Avatar
What size tires is on the truck? 3.55 gears you should get better then the 4.10s. Bigger tires will change the MPGs. You have the smarty is the tire size correct?
My driving habits=
Old 05-01-2011, 09:29 AM
rednekroper05's Avatar
If you are doing a lot of in town driving don't look for much more. I was avg around 16-17 in town with my 3.55s however when you get them out on long runs that's where the high gearing helps. I could see any where up to 21mpg just depending on driving habits when I went on long trips
Old 05-01-2011, 09:57 AM
Chilly7's Avatar
Tire size = 235. yeah I adjusted the speedo with the smarty. It is just weird. I don't drive with a lead foot.
Old 05-01-2011, 10:31 AM
NadirPoint's Avatar
Default Environment Would be My Guess
Are you talking straight highway long-distance, mixed, start-stop around town? Being more mixed mode leaning to start/stop would explain it. Taller gears only translate to better mpg on the highway, all else being equal. Higher gears means worse fuel mileage in urban environments with a lot of start-stop driving.
Old 05-01-2011, 11:27 PM
01quadcab's Avatar
it also depends on if they are trusting the overhead or hand calculated. I will take my 3.55's any day over 4.10's
Old 05-01-2011, 11:35 PM
I liked mine for running down the road empty but my355s killed me towing and in town. It's also a pia for trying to idle around pastures check fences and stuff.
Also it is possible for a truck with 4.10s to get 20plus my old roommate had a 01 3500 that got around 20 mpgs hand calu. on a regular basis
Old 05-02-2011, 12:24 AM
EasternAggie's Avatar
If I had 4.10's I would want a pretty tall overdrive ratio, maybe even a gear vendors.
Old 05-02-2011, 05:28 AM
Chilly7's Avatar
I do about 60% city and 40% highway
Quick Reply: Gears = mpg???
