how much boost w/stock turbo
Old 07-16-2011, 03:57 PM
vegascbm's Avatar
Default how much boost w/stock turbo
how much boost will a stock turbo produce. i have a #6 fuel plate the rest is stock. i will get fresh air intake and get rid of cat&muffler next( if it makes a differance). ?
Old 07-16-2011, 05:22 PM
cumminspwr11's Avatar
it will go all the way to 50ish but does more harm than good, its best to wastegate them at or around 32-35psi
Old 07-16-2011, 07:59 PM
bluedieselram's Avatar
stock 12valve makes 15-20 boost and taking off cat adds 2.5
Old 07-16-2011, 08:27 PM
dipapadakis's Avatar
Yea i got 52 lbs of boost outa my old stocker but u gotta be carfeul way to much drive pressure
Old 07-16-2011, 11:00 PM
big_dog37074's Avatar
I was boosting around 56 psi. which was stupid on my part for doing it. I think thay can start coming apart around 40-45 psi. dont quote me on that, but it some where around there. I had wastegate plugged off with 100hp injectors, 10 plate, .093 lines, timing 16. 3k springs.
Old 07-17-2011, 05:44 AM
vegascbm's Avatar
thank you; wastgate how much that gana cost? ya know its not easy to tow with this truck my 3/4 ton 454 get in & tow ,w/dodge need more power, then be carefull trans cant take it, must have guages ,cooling system needs modification for towing. man i love my truck but using it as a truck.? if i can figure out a solution to the cooling sys.ill be once again happy me,dog 5th wheel,& dodge anywhere but vegas.
Old 07-17-2011, 09:10 AM
banks big head wastegate is like 400-500 & couple of guys i know say its worth the money
Old 07-17-2011, 02:24 PM
olered's Avatar
i got my banks big head for 182 its worth it
Old 07-17-2011, 02:54 PM
dieselzimm's Avatar
just get a boost elbow they are only 20 bucks or so
vegascbm (07-18-2011)
Old 07-17-2011, 05:41 PM
South Tx Coal Roller's Avatar
I second the boost elbow, does the job for cheap.
Quick Reply: how much boost w/stock turbo
