Info on my 1995 Ford 7.3L Powerstroke Turbo
Old 07-24-2011, 07:50 AM
rick.whitaker65's Avatar
Default Info on my 1995 Ford 7.3L Powerstroke Turbo
Hi,
I am new to this sight but it seems to have lots of great information and knowledgeable people.
I have a 95 ford 7.3L Power Stroke Turbo and I need some information of the turbo waste gate valve. Where is it located? How hard is it to remove and replace? I would like to do this myself.
Thanks, Rick
Old 07-24-2011, 10:01 AM
twinboys's Avatar
It does not have a wastegate. It has an EBPV. (Exhaust Back Pressure Valve). It blocks off the exhaust during warm up. This restriction makes the computer deliver more fuel to maintain an idle and sometimes to maintain a speed when still cold and full throttle is not required for power. After the engine is warmed up, the valve opens fully.
Old 07-24-2011, 11:42 AM
Hey,
Thanks for the info. Any idea where I can find out how to replace it? Location, difficulty?
I want to try and do the repair myself if possible to save some money!
Old 07-24-2011, 12:43 PM
CSIPSD's Avatar
How do you know or what is leading you to believe you have an EBPV issue? They are more or less trouble free...
Old 07-24-2011, 06:24 PM
I replaced all the glow plugs and the glow plug switch. The truck will not start unless plugged in during cold weather. In warm weather if you don't let the truck warm up for 20-25 minutes when you drive it it will not go over 30mph for about 2-3 miles. Then it gains full power and takes off.
Old 07-24-2011, 06:43 PM
joebob3093's Avatar
Moderator
Default Re: Info on my 1995 Ford 7.3L Powerstroke Turbo
Your ebpv is probably sticking. You can unplug it and fix that problem.
Old 07-24-2011, 06:58 PM
Can you tell me how to do that? I don't know exactly where it is located. I have been trying to find a diagram to show me....its a 1995 7.3L DI Powerstroke with manual tran
Old 07-24-2011, 07:08 PM
CSIPSD's Avatar
Replace your Exhaust Back Pressure Sensor and tube.
Passanger side exhaust manifold, front. You will see a tube that runs from there to the front of the motor. Replace that tube and sensor.
Your issue will go away.
As far as the truck not starting when cold, sounds like the glow plugs are still not working.
Check this link, might help with the diognostics...
https://www.dieselbombers.com/ford-p...tml#post735911
Old 07-25-2011, 11:02 PM
rorybellows's Avatar
sounds like your g.p. relay might be on its way out or already gone. theyre similar looking to the ford starter relay
Old 05-18-2012, 07:35 AM
I HAVE A 1995 7.3 SD TURBO, IT STARTS AND RUNS GREAT WHEN THE ENGINE IS COOL AND SPITS AND SPUTTERS WHEN THE ENGINE GETS WARM AND SHUTS OFF, HAVE REPLACED QUITE A FEW PARTS AND NOW WONDERING IF IT IS THE CATYLYTIC CONVERTER, PLEASE REPLY ASAP
Exhaust Back Pressure (EBP) Sensor DIAGRAM
Ford Motor Company Publication FCS-12178-97
OR I CAN EMAIL YOU A PIC
Last edited by silverhawkrepo; 05-18-2012 at 07:35 AM. Reason: Automerged Doublepost
Quick Reply: Info on my 1995 Ford 7.3L Powerstroke Turbo
