Faulty fuel reading
Old 07-26-2011, 10:09 PM
rocket02's Avatar
Default Faulty fuel reading
I've got an 02 Dodge with the 1/4 tank faulty reading. (empty)
So is it the sending unit? The gauge?
What can I do to fix it?
Thanks
Old 07-26-2011, 10:52 PM
BACONBITSFORU's Avatar
Mine did that to and it just started... It got to 7/8 a tank and died... Dident even turn on the gas light
Old 07-26-2011, 10:53 PM
And it's a 2001
RAW's Avatar
RAW
RAW is offline
Most likely the sending unit. To my knowledge, they are not repairable.
To replace it, I suggest lifting the bed off, it is much easier then dropping the tank. Depending on the modifications to your truck, future modifications, and lift pump type, I suggest this as a replacement:
Modified liberty fuel module
Old 07-26-2011, 11:10 PM
01CumminsPower's Avatar
Does it have a drawstraw from vulcan performance in it? I know with some of them you can still have 1/4 tank but not getting any fuel to engine
Old 07-26-2011, 11:20 PM
RAW's Avatar
RAW
RAW is offline
That one does, its ready to go.
"We take a brand new Liberty module unit, modify it and install our 1/2" DrawStraw™ system. "
If mine ever fails, it's what I will get.
Old 07-26-2011, 11:37 PM
I got to save some money before I can do this might as well wait and just get this and the airdog at the same time
Old 07-27-2011, 11:46 AM
EggosBrother's Avatar
The same thing recently happened to mine. My first thought was the lift pump went (Truck died at 65mph the day after i bought it). Had an Airdog 100 installed (no draw straw) Died again at 1/4 tank. Put 7-8 gallons in it, purged lines, went to get fuel, it still took 25 gallons. it was completely empty at 1/4 tank on gauge. I plan on ordering The Vulcan module ASAP. Until then i will be filling up at half a tank.
BTW- Thanks for your help on that RAW
Dbleo351
11-20-2016 09:34 AM
Cavnar
09-09-2015 07:18 PM
Jet A Fuel
Tech Article Submission
06-05-2015 03:28 PM
ctjkelley
06-03-2015 06:01 AM
moneypitk5
02-12-2015 11:01 AM
Quick Reply: Faulty fuel reading
